Question about NetGear WGT624 Wireless Router
My netgear router reset & name changed to ''NETHEAR'' & no password-how can i put password on it?
Need to put password on
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,003 Answers
Http://www.fixya.com/support/t25407722-router_reset_now_no_password_only
Posted on Feb 09, 2015
SOURCE:
I need to change the password for my router
http://kb.netgear.com/app/answers/detail/a_id/23439/~/finding-the-wireless-network-password-on-a-netgear-router-using-genie
Jan 07, 2015 | NetGear Computers & Internet
Reset password
The default password for the router's Web Configuration Manager is password. NETGEAR recommends that you change this password to a more secure password.
To change the administrator password: 1. On the main menu, under Maintenance, select Set Password to display the Set Password screen. 2. To change the password, first enter the old password, then enter the new password twice. 3. Click Apply.
Best of luck!
Sep 06, 2011 | NetGear WNR2000 Wireless Router
How do i reset the name of my router and the password
to reset or to change your password, is you need to access the router page, but you have to be directly connected to the netgear, and access the router page by opening a browser and type 192.168.1.1 on the address bar. it would ask you for a username and a password. username is " admin " password is " password " then after that , you would be able to configure, reset and change the name of the router
Jul 25, 2011 | NetGear WGR614 Wireless Router
Need password to my netgear router n 300
what is the model #?
Most netgear routers default to a username of "admin" and password is either " admin ", "password" or it is just blank. Those are the defaults unless someone changed it.
If you cant get in you can hold down the reset button on the back for 30 seconds (while it is plugged into power) and that will set it back to factory default settings then one of the above should work.
If this was a help please give me 4 thumbs up as I am trying to build up my rep on this site!
Mar 02, 2011 | Computers & Internet
I need to change the network name and password
Log in to your NETGEAR router by browsing to http://www.routerlogin.net or http://www.routerlogin.com. Enter the username (admin) and password. By default, the password is password or 1234 unless it has already been changed. From the left-hand navigation menu of the Router Manager, select Set Up > Wireless Settings. From the center screen, select your encryption type from under the Security Options heading If the wireless network passphrase is visible, review it and use it to log devices onto your network.
If it is not visible, you can change your wireless passphrase; however, changing the passphrase will cause you to lose your wireless connection. Connect your computer to the router with an Ethernet cable before entering a new passphrase into the text box and clicking Apply.
If you cannot log into your router: Unfortunately, there is no way to recover a lost or forgotten password from a router or access point; you will need to reset the device to factory defaults. However, once the device is reset to factory defaults, you can use the default username ("admin") and password (either "password" or "1234" depending on your router) to reconfigure your router settings. if there is a small hole in the front or back of the router push a hair pin in to reset to factory settings
Hope this helps don
Feb 21, 2011 | NetGear Computers & Internet
I need to reset or find my origional password. Please help. Thanks
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Feb 17, 2011 | NetGear DG834G Router
I need to reset my password
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, admin and password, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
If you need more help post back! Thumbs and testimonial are welcome!
Feb 17, 2011 | NetGear WGR614 Wireless Router
Can not reset router , netgear wgr614v9 user name
Hello
First unplug router.Then hold reset button in for 30 seconds,button is usually in the back may need a pen tip or paper clip to hold it in.
Then plug back in.Try logging on using admin as username and password as password.
Nov 02, 2010 | NetGear Computers & Internet
I bought a new lap top and can't log onto my wireless because I forgot the passwork. How do I retreive it or how do I reset it?
Press the reset button on the back for 30 seconds. 192.168.1.1 will be then Netgear address, type the address in the and "admin" is the user ID and "admin" is the password. Make sure you change the password.
Aug 07, 2010 | NetGear WGR614 Wireless Router
Resetting WEP Password on Netgear WGT624
If you hold the reset pin in for more than ten seconds(I always count to 15) it will do a Factory reset...this will set all back to factory specs
Then you can set a new wep as well as an admin password
Jan 27, 2009 | NetGear WGT624 Wireless Router
NetGear WGT624 Wireless Router Logo
61 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
