Question about GE WPGT9360EPL Top Load Washer
Maytag top load washter - # LAT8506AAE
WHY THE MACHINE IS NOT SPINNING. IT REMOVES THE WATER, BUT THE CLOTHES ARE SOCKING WET. I CHECK THE BELTS AND THEY APPEAR FINE, BUT SOMEWHAT LOOSE. ARE THE BELT SUPPOSE TO BE TIGHTER? THANK YOU FOR HELPING ME.
  • 7 Answers
SOURCE: washer not spinning the clothes completely
For the the initial filling of the tub, the pump is not involved. The rinse cycle is also done with fresh water supplied by the inlet valve, although the water pump may be running simultaneously to remove the water while it is being added. Try removing front (or top) cover and find the water pump. It will have connecting hoses clamped to it. Check the hoses for blockages first. Then check the pump for any objects inside or broken impeller blades. If impeller is broken, replace it only if possible --- if not, you'll need to purchase a new pump. Hope this helped.
Posted on Dec 22, 2007
SOURCE: GE Front Loading Washing Machine seems to be holding water....
manual
Posted on Mar 21, 2008
  • 128 Answers
SOURCE: GE WASHER SPIN OUT PROBLEMS
Sounds like the suspension for the drum is having problems - there are usually springs holding the drum up and acting as shocks - one of the springs may have come off during an unbalanced load.
Posted on Nov 22, 2008
SOURCE: Clothes still wet at end of spin cycle
Problem may be motor overheating.
I have a GE top load washer with similar problem.
i think that the problem with mine is that by the time the washer runs through the wash cycle and first spin it's warm, then as it begins to spin for the rinse cycle, the thermal sensor in the motor shuts the motor down. it doesn't get spinning fast enough to spin the water out of the clothes. when i put my hand on the motor it is quite hot. in a few minutes it will spin again.
my question is this: can i override the thermal shut down and is it dangerous to do that?
Posted on Feb 13, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Washer won't spin
Check the washer motor. Make sure that the motor is getting correct voltage and is working and spinning when you turn it on. It sounds like the motor is bad. You can remove the back cover to get to the motor to check it out
My neptune front loading washing machine will not spin on the spin cycle. Clothes are soaking wet.
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Will not ring out clothes, still wet after spin cycle.
heatman101
Jan 19, 2011 | Maytag Atlantis MAV6000 Top Load Washer
Every so often, all the water is not draining at the end of the cycle. The clothes are left clean but soaking wet.
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Nov 07, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Clothes still wet after spin cycle
heatman101
Oct 06, 2010 | Maytag Neptune FAV6800AW Top Load Washer
I have a Maytag Neptune front load washer model MAH400AWW that will not drain properly. I have it set to "max extract" and the clothes come out dripping wet and there is always a significant amount of...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 08, 2010 | Maytag Washing Machines
Maytag Atlantis Clothes washer. Unit spins but clothes remain very wet. Where do I start to look for the problem???
heatman101
Sep 03, 2010 | Maytag Washing Machines
I have a Maytag MAH4000AWW. Machine does not drain all of the water out after spin cycles - so clothes come out soaking wet and a little water is left in bottom of drum. Also the Door Lock light does not...
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Aug 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Clothes are dripping wet when I take them out of the washer?
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
Irt sounds as if your pump is somewhat blocked.
See the following for how to remove the cabinet and check the pump for blockage and/or a problem between the pump and motor.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=2edbaee16223b0927cee89fcc394964e
Dec 22, 2009 | Kenmore 22422 Top Load Washer
Machine won't rinse or spin properly..also stinks!
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
May 08, 2009 | Maytag HAV2557 Top Load Washer
Water got stock in the machine
It sounds like the drain pump has failed.
It is located at the rear right of the m/c, and has 2 hoses connected to it.
Sep 02, 2008 | Hotpoint WD62 Front Load Washer / Dryer
GE WPGT9360EPL Top Load Washer Logo
379 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
