Question about Philips 60PP9202 60" Rear Projection HDTV-Ready Television
Philips 66P920217F Chassis DPTV305F
Came in to shop with convergence off. Replacing both V/H IC's 2212344682 corrected the convergence problem, but now no color, only Black and White image on screen. Are there any other components that need to be checked or replaced in the same circuit area? Don't have service data for this set.
Thanks and look forward to reply.
Jay
Have sound but NO PICTURE
  • mavsoffense Nov 20, 2007
    i am also having a convergence issue. How did you replace the IC's ?
  • jortiz26 May 14, 2009
    i have a red loop coming from the top and one going up from the bottom.
    President:
  • 4,402 Answers
There are some resisters that should be checked
other than that make sure you have all the connectors plugged in correctly
heres some diy sites.
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hometheatershack.com/forums/manufacturers-service-support/5600-crt-based-rptv-convergence-repairs.html#post43725
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
Posted on Dec 14, 2007
2 Suggested Answers
SOURCE: Philips 66P920217F Chassis DPTV305F
I fixed that issue on my in-laws set - twice. Both times there was a different reason. First time, I went to the menu ON THE SET ITSELF, not the remote, and had to select an option. Don't remember what, but should make sense when you poke around. The second time was quick and easy, the cable company had swapped the blue and green component cable. Good luck!
Posted on Dec 18, 2007
My magnavox HDTV model #51MP392H/17 the year on the back of the tv is 2004 the picture on the screen looks like its in 3D how can i fix it myself. I tried a new cable box it only worked for a few minutes...
The convergence ICs and resistors have failed. You will need to install a convergence repair kit. The Phillips DPTV305 chassis convergence repair kit is the correct one for your magnavox. Its available at www.tvrepairworld.com and the kit contains the 2 ICs and resistors and the CD with repair instructions.
Jun 16, 2011 | Philips Magnavox 51MP392H Rear Projection...
Color won't converge
This sounds like convergence output IC problem. convergence board would have to be removed - remove and replace 2 STK IC's and check the surrounding resistors. Shops usually $200-$400 Be sure to vote/rate me if this helped Thanks!
See link for more detail
http://www.ehow.com/how_4575598_yourself-projection-tv-repair-convergence.html
Dec 27, 2009 | Philips 51PW9303 51" Rear Projection...
Convergence problem
replace the convergence ic. the IC# is STK392-120, replace this two ic at the same time. then put some silicon grease on the back of the IC for better heat transfer. some will work on replacing just 1 IC but I would recommend to replace both per philips advise. hope this help. regards, cebuwano.
Mar 17, 2009 | Philips 43PP9202 43" Rear Projection...
I have a Phillips projection TV Model# 60PP9202 Chassis # DPTV305F with a linear distortion problem. The colors are not aligning. Can I fix my TV myself, or do I have to take it in. Any advice would be...
It soundsa like you have a convergence problem. Probably only one color. (The green and red may be ok but the blue is bowed or any of those combinations) This will require the repklacement of convergence IC's and then alignment. Probably best to have a experienced tech take care of this.
Nov 26, 2008 | Philips 60PP9202 60" Rear Projection...
Replacing convergence ic on Philips 43pp9202
you can do this yourself and if you buy your parts at the sight I posted you also get pic installation instructions as well as free online tech support
http://servicemanuals.vstore.ca/
May 10, 2008 | Philips Magnavox 51MP392H Rear Projection...
43UWX10B problem with green
if you have a 2 IC convergence chassis they dont control the green , However if you have the 3 IC chassis the green is controlleed by the third IC these are usually STK4275 or simallar single amp ICs. Which type chassis does your hitachi have? Its possibly related to the digital convergence board if all resistor near the ICs are good. Do you have the service manual? I can post a link where you can get the full service manual if you need one
Mar 29, 2008 | Hitachi 43UWX10B 43" Rear Projection...
IF you can solder yes you can fix it yourself. Replace STK-392-110s with STK-392-180s,
Nov 22, 2007 | Philips 43PP9202 43" Rear Projection...
Nov 02, 2007 | Philips 50PP9202 50" Rear Projection...
Philips W46951
Blue convergence IC defective.Will require chassis pull.Senior technical skill level needed.
Sep 25, 2007 | Philips 55P8241 55" Rear Projection...
No horizontal red convergence control
Probably the red convergence output IC has failed. The chip is basically a stereo amplifier that serves as a horizontal amplifier and a vertical amplifier. I suspect the vertical part has failed and is not uncommon. Should be generic STK392-150's or maybe STK392-110/120 I believe. By the way when the line moves up and down that means the vertical is working when it moves side to side the horizontal is working.
Feb 03, 2007 | Philips 60PP9202 60" Rear Projection...
Philips 60PP9202 60" Rear Projection HDTV-Ready Television Logo
1,053 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
