I have tried to soak it up in rice and that didn't work.I tried to wait til it dried out on its own but when u press in the screen it still looks wet.The model number is NX008HD8G
I hope it was clean water! You should be able to pop the screen off by using a knife on the edge and gently pry all the way around until the screen comes loose, then dry out. Whenever anything electronic is soaked in water, the first thing one should do is disconnect the battery; too late now, but perhaps it will not hurt. If power is connected, electrolysis takes place which can ruin the circuit board and/or components. Dry naturally, or with a hair dryer (not a lot of heat), and you may be okay. Do not power up until it is completely dry. I hope this helps. Good luck and God bless you.
Testimonial: "Thanks a lot i will try it. Do i pop the front screen off?"
