Question about GE (PSS26MSRSS) Side by Side Refrigerator
Model TFX22ZPDAAA GE side by side
Back of freezer wall gets fuzzy ice build up. Freezer stays cold but refrigerator side gets warmer and warmer. Need to thaw once a week. Need to know if it is ADC board, thermostat, or defrost heater assembly.
Thank you very much.
  • 248 Answers
It's usually the defrost heater on this model. Pull rear panel of freezer and remove the heater, (2 screws). It's at bottom of coils. Take to your parts place and they should be able to ohm out for you to see if it's ok. If it's all blackened, probably heater.
A check you can make is to pull refrigerator out to access back. UNPLUG UNIT!
Remove panel over control board on back of fridge. On the blue connector in bottom of board note the defrost terminal as specified on board. Unplug connector and put a jump wire from this terminal on the CONNECTOR, to the terminal that has the wire going to it with no wire next to it. Plug in refrigerator. If defrost heater is good, it should start glowing red within a few minutes. If it doesn't replace it.
Posted on Nov 14, 2007
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
My whirlpool gold two sided refrigerator, model #6D5RHAXNB00, the refrigerator side is not getting cold enough! I can't feel any cool air coming through the vent on the left upper corner.
your freezer may be iced up not allowing the cold air from the freezer to blow into the frige .you may see a ice build up on the back wall of the ice build up can also stop the fan.if you can leave the unit off for 12 hrs or longer to thaw and that helps after restarting you may need to change the defrost timer ,defrost heater or both.a faster way is to remove the covers if you can do that.
Jan 15, 2013 | Refrigerators
Ge refrigerator is not cold enough and ice is not working
What is the model number?
The ice maker will only run if the freezer is at the correct temperature.
Do you see any ice buildup on the back wall of the freezer or behind it?
Nov 27, 2012 | Refrigerators
Side by side refrigerator/freezer which is getting ice build up on the back wall coils of the freezer which does not allow the freezer or refrigerator to cool.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
Jun 20, 2011 | GE Refrigerators
Freezer side gets very cold, but the refrigerator side is slightly cool. Replaced thermostate but the results are the same.
It may be a defrost issue. If the freezer is not defrosting then ice encases the fan motor behind the back wall of freezer and wont allow it to circulate the cold are to refer section. To see if that is the issue check behind the freezer back panel if it is iced up try unthawing it, have towels on the floor it will make a mess, if it starts cooling again after you thaw it out then you know its a defrost issue and it will work until the ice builds up again. You may need a new defrost tstat, heater or timer.
Oct 13, 2010 | Whirlpool ED5THAXMS Side by Side...
We have replaced our G.E. side by side refrigerator mother board ,it did fix the problem with the ice maker and water not working ,a week later ,the ice started to build up agian and fridge is not getting...
The bdefrost heater behind the wall inside the freezer is bad if the ice you have is on the back wall of the freezer. Remove the back wall and deice the coils and replace heater. wr51x10101
May 25, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a ge gsl22wgph and the refrigerator side is not is not getting cold enough and the freezer side is not freezing. What is the problem?
First look at back wall of freezer toward the bottom and see if you have frost build up on the wall. If you do the problem is most likely the defrost heater and you will need to remove back wall of freezer, melt the ice from the coils and then change the heater at the bottom of the evap. coils.
Apr 17, 2010 | GE Profile PSW26P Stainless Steel Side by...
My freezer all of sudden isnt keeping things frozen..and the fridge isnt staying cold
ck in back of freezer for ice build up . if so the defrost system has failed . if may need a heater or timer( control ) to correct problem . the frost in the back of freezer blocks air flow and the fresh food area does not get any cold . and then the freezer gets warmer . and ice cream is not hard .. hopt this helped ****
Feb 10, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator has a bulge on the outside of the cabinet on left side where the ice maked is located and that side of the box is cold and sweating
Empty the ice from the ice maker. It sounds like you have a build-up of ice between the ice maker and freezer wall. When you thaw this ice, the bulge should go away. You may need to temporarily move the ice maker for a few hours while the freezer thaws.
Feb 05, 2010 | LG Refrigerators
GE (PSS26MSRSS) Side by Side Refrigerator Logo
269 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
