Question about Office Depot Ativa DQ60M Shredder
Won't run in auto
My atvia runs in reverse only. When switch is in auto position, it will not run.
  • Anonymous Dec 30, 2007
    Same problem. Checked the optical sensor & this is OK. 5k6 10W resistor on control board gets hot . Anyone got a schematic for this unit?
  • Anonymous Jan 03, 2008
    Same thing only mine's a Staples SPL-1506X. I was naughty and overworked mine last night. The red light goes on whenever I switch it to auto. The blades go in reverse for both auto and reverse modes. I'd like to get in and fix it myself rather than pay someone. If anyone gets a schematic, I'd like one as well. Thanks - Happy New Year.
    Problem Solver:
  • 17 Answers
The facts that the optical sensor is ok, and a high wattage resistor gets hot, indicates a mechanical problem, i.e. it's actually stuck (there may be a different power rating in the cpu, that means that by automatic, it stops by for example 1 Ampere, but by manual, there is no current check, i.e. the cpu delivers what the power supply is able to give. could be several A's, which will in turn burn the motor if you try the manual too long....)
So, unplug the power cord, and try to move the mechanics by hand, and you will discover the problem.
Posted on Jan 06, 2008
New mower McCulloch riding mower won't start after ruuning in reversenew mower
Take a look at your switch..you most likely have a third position switch..meaning a off start position and back to run.after starting...but a middle position between start and run is added not to allow to run or start in reverse you must manually move the switch to the middle..or put the gears in neutral...if not that one of the safety switches is not functioning right..new so warranty should fix that..good luck.
Apr 29, 2014 | Briggs & Stratton Garden
Tip
When the furnace blower runs all the time.
Usually when the furnace blower motor runs all the time
The limit switch or rollout switch is usually open or bad.
The furnace board is seeing that one of those switches is open, so it brings the blower on to try to get the heat out of the combustion chamber area, so the switch will close. But if the switch is bad and won’t close, the furnace board will keep the blower running continuously.
Make sure the fan switch on the thermostat is not in the "ON" position it should be in the "AUTO" position.
on Dec 30, 2009 | Heating & Cooling
Overload light stays on
Most likely the cutters are still stuffed with paper shreds and needs to be dismantled and cleaned
Mar 29, 2014 | Honeywell Seven Sheet Micro Cut Paper...
Runs reverse auto
From your manual!
In case of a paper jam , which may occur if the shredder is pushed beyond its specified capabilities, press the control switch to the off [O] position and empty the basket if full. Then:
1) Press and hold control switch in reverse [R] position and attempt to back paper out of shredder.
2) If shredder jams in reverse mode, press control switch to automatic [I] position and attempt to continue shredding operation.
3) If shredder jams again, alternate control switch slowly between reverse [R] and automatic [I] positions to attempt to move jammed paper completely through shredder.
If you are unable to clear the jam using this method, turn off and unplug the shredder; remove the wastebasket from cabinet and carefully remove any paper extending below the cutting cylinders; empty the waste basket; insert waste basket and repeat jam clearing procedure.
Feb 01, 2014 | Fellowes DM12C Shredder
Model 6k890 motor
Will the fan run with the fan switch in the ON position? as opposed to the AUTO position. If so the temperature or time delay or motor may be bad.
the fan switch operates the fan relay that controls high/cooling speed, heat speed is a time or temp delay.
Oct 25, 2012 | Dayton Gas Furnace Heater
All fuses are good - brake lights, rear running lights work fine. but the reverse lights won't come on when put into reverse. Any idea what might be going on? As far as I know the bulbs are still good...
You will need to either replace or adjust your backup switch, it is located on the transmission next to the shifter. Hope this helps, thank you for using FixYa!
Jul 06, 2011 | 2000 Pontiac Sunfire
The shredder was paper jammed
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds.
Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled.
Follow instructions to oil your shredder;
To keep your shredder in top condition, the cutting blades need to be oiled every so often (for frequency, please refer to your owner's manual). We recommend using Powershred® Lubricant or a vegetable-based oil (such as corn or canola) in a non-aerosol container with an extension nozzle.
Caution: Never use flammable synthetic oil, petroleum-based, or aerosol lubricants to oil the cutting blades. Some agents may combust, causing serious injury. NEVER USE WD40.
1. Depress and hold the reverse button down.
2. Put the tip of the oil bottle in the paper entry and make one or two sweeps the length of the entry while squeezing the oil bottle.
3. Move the power switch to Auto (I) position, or depress the manual forward button (depending on model of shredder) and allow the blades to run at least three seconds.
4. Move the power switch to Reverse (R) position and allow it to run for at least three seconds.
5. Repeat steps three and four above at least three time.
Regards.
Apr 20, 2011 | Geha Primo 1400 Shredder
My fellows jbo1 jamed and then stopped running is there a reset buton?
Chances are it's over heated.
Ensure the wastebasket is empty then move power switch to the REVERSE position. This will reverse the jammed paper out of the shredder. If shredder jams again, alternate control switch slowly between REVERSE and AUTO (l) positions to attempt to move jammed paper completely through the shredder. If the shredder jams in reverse mode, move the switch to AUTO (l), depress the manual forward button located on the center of the shredder head and allow to run for five seconds. If jam does not clear, move switch to REVERSE again and allow to run for five seconds. Repeat this process until jam is cleared. If necessary, turn off shredder and use care to grasp the paper and carefully pull out to clear jam. Once cleared, move switch to AUTO (l) to continue shredding. The jamming may be happening because the cutting cylinder needs to be oiled. See oiling instructions below.
From fellow's website: http://www.fellowes.com/fellowes/site/support/support_troubleshooting.aspx#jammed
Dec 15, 2010 | Fellowes Office Equipment & Supplies
The shredder will run in reverse but will not run foreward.
Inside the shredder there is a motor which is wired to run both forward and backward, the way it does this is to transfer the power from the switch to a couple of wires on the motor
The forward running motor will be linked to the auto start button which will tell it to work with the paper sensor.
When you select the Forward function the Auto Start is taken out of circuit and the Forward switch should supply the motor
After all of that I would say that the switch is open circuit on the Forward contact and needs replacing
Jun 12, 2009 | OfficeMax 0M96431 Shredder
Ativa DQ 120dDoesn't run in auto
I personally work with Fellowes brand shredders, but it sounds like you have a paper feed sensor issue. This may be a mechanical or electronic sensor located in the center of the paper feed slot. If it is electronic it may just need cleaning(qtip dipped in rubbing alchohol. If it is a mechanical sensor check to make sure it has not been broken or it may be stuck because of paper that has become wedged behind it(you may need to jiggle the switch a few times to free it). If none of this works you may have a burned out switch or a bad pc1.gif board, contact manufacturer for more info.
Jan 05, 2008 | Office Equipment & Supplies
Office Depot Ativa  DQ60M Shredder Logo
447 people viewed this question
Top Office Depot Office Equipment & Supplies Experts
Anthony Karuku
quennie732
Stan Marciniak
Stan Marciniak
Level 1 Expert
Are you an Office Depot Office Equipment and Supply Expert? Answer questions, earn points and help others
