Question about GE Profile PSI23NCR Side by Side Refrigerator
GE fridge freezer profile
Our fridge freezer is 2 yrs old and we think the computer panel is not working any more , this on the advice of recommended repair company, 1st it stoped making ice, then the water dispencer and finally the whole frige packed up
  • 306 Answers
The fridge needs servicing....if you still have waranty use it.
Posted on Nov 12, 2007
Ge tfg27pfxa profile with cooling problem
Remove the back panel in the freezer to see if the defrost heater is running continually.
Nov 06, 2012 | GE Refrigerators
Profile GE PS123Sc about 6-7 yrs old. Freezer side seems fine. Fridge side is too warm, but is cooling (about 40F). Fridge side lights are intermittent and control panel at top is intermittently dark or...
Sounds like a bad motherboard and probley need control board. You can put in self dianoss. Press all the buttons on panel for 5 seconds. This will start the program. It will check all sensors. Come back with codes and I will help you. Wait to hear from you. I hopes this helps. david_gra582
Aug 27, 2011 | GE Profile PSS26NGS Side by Side...
Bottom freezer door left slightly ajar for approx. 24 hours on a GE Profile fridge. Now, freezer and fridge are at 28 and 54 degrees respectively and will not return to normal. What are possible...
Hi do you notice any frost in the back of the freezer? If you do not this is a bad motherboard, I would recommend calling GE directly if under 5 years old they will fix at an extremely discounted price if it over 5 then the board costs about $175.00-200.00 to buy.
Mar 28, 2011 | GE Profile PDS22SBRR Stainless Steel...
Have a GE Profile bottom-freezer refrigerator, model #PDS22MBSBWW, serial #RL053351, approximately 5 yrs old. It has recently started making a "clicking" sound which goes on for anywhere from 1...
For the clicking if the fridge has been off for at least 5 min. and clicks when it tries to start then it may be the start relay on the compressor . If it does not stay off for at least 5 min then it may be the control which may also be why your display is not working.
Nov 30, 2010 | GE Profile PDS22MBS Bottom Freezer...
Refrigerator not keeping temp.
There is normally a fan in the freezer (usually removing the back panel from inside the fridge will show it [sometimes you need to pull the bottom panel of the freezer off] The panels are normally secured with phillips head screws.). If it doesn't turn, it probably needs replacing. Make sure the coils are not iced over. [unplug while removing panels, then plug back in... the temp will have risen in the freezer so the fan should come on right away].
Make sure that the "vents" in the freezer (bottom of the freezer - in the front back or both) are not covered.
Some fridges have a separate control for fridge temp, make sure that was not moved, or try setting to a colder setting.
Sep 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE fridge is warm and broken; the freezer is cold though.
Air circulation problem. Evaporator fan in freezer moves some air to refrig. Either fan is not working or air passages are blocked with ice. If ice found, then a defrost component failure has occurred. Fix what you find.
Sep 19, 2009 | GE Profile PDS20MFS Bottom Freezer...
GE Profile stopped making ice. 2 yrs old
clean the coil behind the fridge or under the fridge (where ever they are) and make sure both fans are running, the one in the freezer and the one underneath freezer needs to be 0 degree F to start ice maker
Aug 07, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp control. Make sure the fan is running when the compressor runs. Make sure the vent(damper) opens and closes as you adjust the fridge temp control.
Jun 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile French Door Bottom Freezer not cooling
I am experiencing the same problem with my GE fridge. We have already tried the Turbo Cool, but nothing seems to help.
Nov 13, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE Profile PSI23NCR Side by Side Refrigerator Logo
135 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
