SOURCE: my eagle talon will not start
have you checked the fuel pump relay it's under your audio system in front of your cars computer.
SOURCE: 1995 eagle talon wont start
Hi
You did not specify if its petrol or Diesel I am assuming it is diesel. It might be the glow plugs. Get them checked as you will need these to get it started. If its petrol its a different issue. It might be the ignition coil (no spark) coming to the distributor. Whichever the type of car make sure that there is fuel coming to the engine. In the case of diesel you should have a primer rubber fuel pump which you press in order to bring fuel to the engine.
Hope this was of help to you :)
Thanks
SOURCE: up my boost on 97 eagle talon
Hello, I wouldn't up the boost without supporting mods. The stock motor will take 18psi of boost, but you run the chance of over heating your internals, hitting fuel cut, leaning out your fuel mixture to much, and all sorts of other bad news.
SOURCE: what is the firing order from left to right on the
Here are the locations of where the plug wires connectCoil
1 4
2 3
[front of vehicle]
engine
1 2 3 4
[front of vehicle]
Here is the engine firing order 1-3-4-2
Testimonial: "wow, that was super quick. thanks!"
