Question about Samsung Radio Communications
I have a Schwinn Blue Tunes Bike Speaker. It pairs to my Samsung galaxy S4 through Bluetooth with no problem. I am able to control my spotify account with no problem using the device. I am able to play, pause and skip tracks. However, even though the device is paired through bluetooth there is no music coming through the speaker. I've adjusted the volume on my phone all the way up. And use the volume control on the blue tunes device. I can hear static white noise coming through the speaker but, no music. Has anyone had this problem or no any possible solutions I can try before I return the device to amazon? Thank you
    Sergeant:
  • 399 Answers
It seems many people use only the term "paired" when talking about CONNECTING two Bluetooth devices. Connecting two Bluetooth devices means first "pairing" them and then "connecting" them. Pairing is a one time process done only the first time you try to connect the devices. It is like the two devices getting to know about each other. Next step is to actually connect the two and this process is done the first time after the pairing and then every time you want to use the speaker from your phone. When you open the Bluetooth tab on your phone's Settings menu you will see the names of all the Bluetooth devices it has been paired with previously and a "Paired" word next to it. If you want to use the device/speaker, tap on the name and it will CONNECT to it. You will see the word "Connected" instead of "Paired". Now you should have the music that you play on the phone coming out through the speaker. If you still can't hear the music over the speaker after a successful connection, turn up the volume on your phone (and on your speaker, if it has its own volume controls).
Posted on Feb 08, 2015
SOURCE:
How do I pair my Samsung Galaxy J3 with my bt 02A2 Bluetooth speaker
Hi Sandra,
Press and hold the power button on the speaker. The lights on the speaker will start flash red and blue. Now open up the bluetooth menu in your phone and search for new bluetooth devices. Once you see the device, select it. If it asks for a pin, try 0000.
Mar 13, 2017 | Samsung Cell Phones
Is the bluetooth on Capella sleep and sound alarm clock, CR50, compatible with an Android samsung galaxy s4? I can't get it to pair
Samsung Galaxy S4: Trying to pair by Bluetooth to Capella CR50 Desk clock: Unable to pair:
Hello..
Yes, the Capella CR50 should be able to Bluetooth pair with any device that can connect via Bluetooth (as stated in the Capella product description).
If you are not able to connect try doing the following (process of elimination) to resolve why this is happening:
  • Turn off and turn on again Bluetooth mode
  • Try resetting the Bluetooth app in Applications>All Applications under Phone Settings
  • Try eliminating apps that may be affecting the bluetooth connection.. you can narrow this down by rebooting the phone into Safe Mode. If in Safe Mode, your S4 is able to connect via bluetooth to the Capella CR50, that will tell you that it is software related, and most likely an app that you installed that is not playing nice with your phone. You can either remove apps one by one and retrying to connect via bluetooth to find and eliminate the issue, or remove all the apps you installed and start fresh.
(Note: removing an app with erase any settings you set up as well as any database within the app (such as a game with scores/levels/and any rewards you received/purchased, unless that database is saved in an online cloud account you sign into specifically for that app, or sync to Facebook (FB) while having the game installed in your FB account
How to get S4 in and out of Safemode:
How To Set Up Bluetooth On Your Samsung Galaxy S4 Phones 4u
Jan 29, 2016 | Samsung Cell Phones
Wireless headphone connection on Samsung UN40H6203AF
Are the headphones regular wireless (with a transmitter, sometimes called base or dock) or are they Bluetooth headphones ?
Jan 01, 2015 | Audio Players & Recorders
How to pair the samsung galaxy s4 to the jabra cruiser
  • Touch Apps
  • 2.Scroll to and touch Settings
  • 3.Ensure Bluetooth is turned on
  • 4.Touch Bluetooth
  • 5.Slide the Power switch to turn the JABRA CRUISER on
  • 6.Press and hold the Multifunction button until you have a rapid flashing blue LED
  • 7.Touch the JABRA CRUISER in the list of devices
  • 8.The JABRA CRUISER is now paired
  • 9.The JABRA CRUISER and Galaxy S4 are now ready to be used
  • 10.Press the FM button in order to start streaming audio via the FM transmitter. The FM LED will turn red
Oct 01, 2014 | Jabra Cruiser InCar Speakerphone Black
How do I fix my galaxy s4 wireless bluetooth pairing with panasonic cordless kx-tga651?
Have you tried to see if it was bluetoothed? An was the bluetooth on on your Galaxy?
May 25, 2014 | Panasonic KX-TGA101S Cordless Handset
PS 7200 SYNC WITH SAMSUNG S4 PHONE
Hello. When you pairing a blue tooth with a samsung if required a code it would be 0000 unless is a specific code by the manufacturer.
Fix: turn off the blue tooth on settings on the phone and turn it on. Let the phone scan for devices, if it says found p that should it. When you see it on the phone press on it, the phone and Bluetooth should pair by doing so. I hope this helps. Good luck.
Mar 04, 2014 | Samsung GALAXY S4
Connect bluetooth
Go to Settings > Bluetooth > (Find the speaker you are trying to connect to and delete it from your "Paired Devices" list.)
Then, try it again! Voila!
Oct 28, 2013 | Samsung Galaxy Tab 4G 10-in 32GB White...
Music won't play on my bluetooth headphones.
If your handset does not support stereo music on blue tooth headset, then you can not hear music on blue tooth head set. However you are able to answer and make calls through blue tooth headset.
Jan 08, 2009 | Motorola Mobility MOTOKRZR K1 Cellular...
Radio Communications Logo
161 people viewed this question
Top Samsung Radio Communications Experts
Anthony Ward
Anthony Ward
Bobby G
Bobby G
Damen Wong
Damen Wong
Are you a Samsung Radio Communication Expert? Answer questions, earn points and help others
