I have a 2000 model vectra 2.6 sri,My stereo light is lit up but doesnt work,And my trip computer lights up but doesn't display the radio channels and when I turn my ignition off my trip computer and
Tried turning the engine off,Leaving it for a while and coming back,but the lights won't go out and the stereo lights are still showing and the ignition is still showing.Checked the fuses all are fine.
It appears to be that the radio clock display has malfunctioned, and is due for a replacement radio, which could be an aftermarket or oem radio, maybe found at a junk yard.
Tools required for oem replacement radio, torx keys set.
Before working on the radio or other electronics, disconnect the battery cables with 8mm wrench.
Replacing the oem radio is much easier, if you obtain oem radio, compared to aftermarket radio, due to being direct fit.
The radio is same for 1995 to 1999 Pontiac Sunfire and the Chevy Cavalier, regardless of sub models, such as SE,GT, VL,VLX,Z24. etc.
Parts needed for the the aftermarket radio install :Stereo assembly, stereo wiring harness adapter, radio antenna adapter, and dash install kit.wiring diagram for the wire colors / functions, along with tools, such as torx key set, screwdrivers,wire crimper, wire stripper, double ended wiring connectors, hair dryer.
The oem stereo removal video is for the 2000 to 2005 Sunfire / Cavalier, but are the same or very similar procedures.
Sorry to tell you this needs to have the code reset once you remove the battery the stereo needs to be reset only a garage can do that there is no doubt about it. Hope this helps Best wishes, Malcolm Campbell.
It is a common issue. there is no easy fix. The radio will have to be repaired or replaced. The least costly option is an aftermarket unit. You can have new unit installed for less than $150usd
