Question about Kenmore Kitchen Ranges
What kind of thermal fuse is in a Kenmore C970-635121 range?
I have a Kenmore electrical range I purchased in 2005. Everything works well, except that the oven recently stopped working. The elements are not broken so I thought that it could be a just a fuse. I can't find any thermal fuse in there, only two GP 15 amp ones. Anyone what kind of fuse am I looking for?
  • Antony Capo
    Antony Capo Feb 08, 2015
    Thank you for the answer Shane, but I can't find anything that looks that fuse in there...is it possible that there's no thermal fuse??!
  • Antony Capo
    Here's a picture:
    Habit-Forming:
  • 29 Answers
    New Friend:
Hey Anthony - any luck on this? I have the same oven and the same problem, any luck on figuring it out? Thanks
Posted on May 25, 2015
Testimonial: "Actually, I've found out that there's no thermal fuse on this model. I ended up buying a new one."
SOURCE:
My Kenmore model 950 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did
Most of the time, when BOTH the oven bake and broil elements don't work, it is usually caused by an open thermal circuit breaker or fuse. When did your oven stop working? After a self-clean? This is the most common cause of one of these thermal fuses opening. Usually this device is located on the back of the oven. A few of them are manually-resettable; but most of them are one-shot thermal cut-out devices (thermal fuses) which have to be replaced once they have been triggered.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Dec 28, 2014 | Kenmore Kitchen Ranges
My Kenmore model 790 range will not broil or bake. The control board seems to work and allows me to set the temp, etc., the clock works, the control board makes noise which sounds like it always did w
My stove top works, but the oven does not. While preheating oven it gave a loud boom, everything went black in the oven and nothing worked!!
Sounds like you got an electrical short. Pull out the range, unplug it, and then check the electrical connections where the wires go into the range. If that's okay, then check the oven bake & broil elements. Also check the electrical connections to those elements. I'll bet you'll find one that shorted to the back of the oven.
Sep 30, 2014 | Kenmore 30" Electric Self Clean Drop-In...
I have a kenmore electric range model #790.95032504 everything works except the oven i replaced the lower element with no luck.i used a volt meter and checked the outlet,where the cord attaches to the...
IT very likely could be the oven control, use your meter to check for 240vac at the element if does not have 240 volts ac the oven control probable isnt sending power to element. WHILE ACCESSING ELEMENT TO GET TO WIRES TO CHECK POWER UNPLUG AT WALL OR TURN OFF BREAKER TILL READY TO CHECK
Aug 03, 2011 | Kitchen Ranges
Kenmore Electric Dryer , 700 series, MOD 64722400 , SER MR4136705 , Type DWJR-ELE-2406028-FM64 . Dryer is not heating, checked fuse it's fine, cleaned every nook and cranny with a swifter duster and...
Hi.
Be sure that you have checked the thermal fuse. The part is tested using a multimeter set on Ohms (impedance). Remove the fuse from dryer and read impedance touching the fuse contacts with the two multimeter probes. If impedance is Ohm infinity (open), then the fuse is bad.
If the fuse is OK because tested good or replaced, then the problem is either one of the three thermostats located in the heating group, or the heating element. All parts are tested similarly to what described for the thermal fuse. If any of the parts read open (infinity), then the part is faulty. After finding the defective part remove all the lint from heating assembly and air duct. The lint causes overheating and blows thermostats, fuse or element.
Regards.
Ginko
Jul 14, 2011 | Kenmore 64722 Electric Dryer
The oven does not work. The self clean does not too
kenmore self cleaning range c970-595084 everything works except the oven will not heat up,on self clean door locks but thats all, top elements work, lights work, digital display works, but no power going to oven elements when i used a tester to check voltage. Can anyone tell me what to do? Is there a fuse for the oven only?
ANY HELP IS APPRECIATED.
TY Fr; Clyde
Mar 15, 2011 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Kitchen Ranges Logo
773 people viewed this question
Top Kenmore Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
