Need to install back seat covers - Must be able to remove the bottom part opf the back bench.
1. Pull the plastic panels under the seat bottom straight forward to remove them.
2. Remove the six bolts (14mm) holding the seat and center seatbelt in place.
3. Pop the two small plastic covers at the top and behind the seat using a trim removal tool or screwdriver tip covered in masking tape.
4. Lift the seat straight upward.
5. Remove.
The Service Manual states a 35 ft lb torque and must be re-installed in a certain sequence for the 6 seat anchor bolts (not the seat belt bolts). When putting the rear seat back in install the bolts in this order. (1) center left (2) center right (3) left lower (4) right lower (5) left upper (6) right upper.
