Model #Gld 5800010ww purchased in 2009. When I press start normal wash, the error code 5h comes up
The GE dishwasher error codes I have seen start with a letter (usually "C") not a number. I suspect that this isn't an error, but an indication that you have activated the system to delay starting the dishwasher. I believe 5h represents a 5 hour delay. Pressing the "Delay" button should cycle through the different selections and eventually bring it back to Zero.
SOURCE: LG LD2060SH has no error codes but cannot set prog...
First check water inflow to the machine. If there is no water machine may not start.
To ascertain further, pour water into the wash chamber manually to the require level and run the machine. If it works check the water inlet.
SOURCE: Maytag model MDB4651AWW3 recently the
Hi
If you have already tried leaving it unplugged for a while then the issue is with the control board that has gone bad and should be replaced to solve this issue. You can also try to blow some compressed air on the electronic control and see if that works. Hope this helps...please post back for further assistance.
Daniel
SOURCE: frigidaire model number gld 2250, gld 2240
read your owner manual section troubleshooting and see the
problem for e.codes.
if you do not have it download from www.retrevo.com
or get support from frigidaire via online, chat or phone
God bless you
I appreciate your inquiry, friend!
Based off the information you have provided your Frigidaire dishwasher is displaying an error code of "5H". That appears to be the time remaining on your wash cycle. Typically an error code would be displayed with a number and an "E". What is the current problem with your dishwasher? Are you getting long wash times? There is a sensor inside of your dishwasher that reads how dirty the water is, if your dishwasher continues to circulate dirty water it will tell that sensor to continue washing. You may want to check your filter, which is located at the bottom of the tub, for any debris. Additionally, if your drain hose is restricted it may be providing dirty water back into your tub. I hope this information is helpful to some degree. -Matt
Good Morning steven hutchings, thanks for your inquiry!
I understand that your Electrolux dishwasher is displaying an error code 03. Normally, error code 03 means an issue with the wash motor, wash motor hall sensor, or control panel. I would suggest performing a reset on your dishwasher that could help clear any false error codes. You can reset your dishwasher by flipping the household circuit breaker in the off position for ten minutes. If you continue to have an issue with your dishwasher displaying an error code 03, I would recommend having a professional technician come out and properly diagnosis your dishwasher. This will help to avoid any unnecessary part purchases. Hope this is helpful. -Matt
