Bissell 1867 steamMOP Stick Vacuum Logo
Posted on Jul 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Bissel steam mop - no more steam
Already tried replacing the filter. suddenly just does not steam anymore - but can tell it is trying. any way to check for clogs/blocks to water flow? worked great for over a year.
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Sep 17, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
Helped
3768
Points
7
You have to open up the cleaner, disconnect the pump from the steam chamber you then have to put it in a vise and remove the brass hose fitting on each end. Clean the springs and chambers but the main thing is a channel that joins the two chambers has to be cleaned out.
John
Anonymous
Level 2:
  • Expert 173 Answers
  • Posted on Jul 08, 2009
Anonymous
Expert
Level 2:
Answers
173
Questions
0
Helped
72311
Points
338
Heating coil defective
Bissell steam mop water filter will not work even though it's new
Either it is installed incorrectly or there may be a leak or clog before or after the filter. Double check your connections and check for clogs.
Calcium Water Filter for Bissell Steam Mop Cleaners
800-775-6586
GoodVac com
Bissell steam mop
-Pump is out (Broken). or water line is clogged.
Good Luck
Mai
Shark Euro Pro Steamer
Hi, you could try the following steps, if you have not done so already. Some of these steps may seem like common sense, but it's for people to forget about checking the least expensive part to replace first, so if some of the steps are those that you have already tried, then feel free just to skip through to the ones you have not tried already.
  1. 1
    Make sure the power cord is plugged firmly into the outlet. The steam mop will not start if it the power cord is loose.
  2. 2
    Check the fuse box or circuit breaker connected to the outlet the steam mop is plugged in to. Replace any blown fuses. Reset any tripped breakers.
  3. 3
    Check the water tank if the Shark steam mop will not produce steam. Add water to the tank if it is empty. The mop will not make steam without water in the tank. To fill the tank, turn the tank cap counterclockwise and lift it up to remove it. Set the filling funnel into the tank opening. Pour water through the funnel into the tank until the water level reaches the "Max" fill line on the tank. Replace the cap.
  4. 4
    Inspect the microfiber cleaning pad if the steam mop is leaving water on the floor. If the microfiber pad is too wet, it will leave water on the floor. Unplug the mop from the wall outlet. Replace the microfiber cleaning pad. To replace the pad, move the latch strips out of the hooks on the mop head. Pull the pad off. Set the new cleaning pad on the mop head. Hook the latch strips onto the hooks on the mop head.
  5. 5
    Use distilled water if the steam mop is leaving white spots on the floor. Hard water may cause white spots to be left.
If none of the above work, then is it something that you purchased recently, and is new? If you did, then it could still be fixed under the manufacturer's warranty regardless of whether or not the original length of the warranty has expired. This could be due to the fact that you have received a product that has some sort of manufacturing fault, rather than it stop working through misuse by the user.
If it's a common problem, then you will more then likely be able to return it to the manufacturer and have it replaced for a new one, let alone repaired :-) - This only applies to whether or not the item is New though :-).
Hope this info helps
Apr 29, 2013 • Vacuums
Pump stops after about 5 minutes use
We know how frustrating it can be when the steam stops when you're trying to clean.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=18994&cid=ccsocial
I was using my shark steam pocket mop without any trouble for about 5 minutes & all of a sudden it stopped steaming. i tried unplugging it & starting over but when i did this the water chamber...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the Shark Manuals that you need.
heatman101
[]0-0-
I have the standard steam mop. It rarely puts out
its under warranty contact bissell the unit will be replaced by a local service center if you have any problem let me know
Dec 10, 2009 • Vacuums
It doesn't steam up anymore.
Hi,,
heatman101
5helpful
3answers
My steam mop all of a sudden stop steaming. The
heatman101
jr
21helpful
3answers
Shark Euro pro mop the ligt wont turn on anymore.
my husband fixed my shark steamer by taking it apart and testing it wire by wire .the problem ?a fuse hidden inside the unit..unscrew the screws and get inside the steamer .at the bottom of the steamer there is a gold orange foil looking piece .under that is a small fuse .unless you can find another fuse just cut that one off and rewire the wires together .shark now comes on
Top Bissell Vacuums Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
