I have not tried anything so far other than cleaning the external body and the hose fittings etc.
Testimonial: "Thank you for your answer, not useful sadly. Regards Carolyn"
Fortunately the problem you describe is not model specific. All Jura machines in the series C, E, F, J, S & Z models have the same problem. The Jura recommended maintenance is insufficient or erroneous. Here is how it occurs:
1- When new machine is set up, the instructions advice the owner to set up OK for use of Filter cartridges. This set helps only to display reminders for replacing the filter.
2- The initial set up instruction also advises that with regular use of Filter, descaling the machine will not be needed. That is really not accurate. Consequently, the reminders for descaling are delayed for over one year or more. This causes serious consequence with accumulation of Calcium deposits in the entire hydraulic and coffee system.
3- Use of Filters alone does not prevent Calcium deposits. Cleaning tables recommended & sold by Jura do not remove Calcium deposits in the coffee/water passages. The automatic descaling method recommended by Jura leaves the coffee side of the machine unclean. The error message in your machine is due to Calcium deposits in the Brew group, coffee outlet & the faucet dispensing coffee in the cup. I suggest all Jura machine owners should manually descale machine. Manually descaling includes use of 6 to 10 rinse cycles with descaling solution in the water tank. The error message "Clean Machine" is accurate. This error message is pointing to descale the Brew group, coffee outlet tube and coffee dispensing faucet by using rinse cycles.
After the rinse cycles are complete, refill Descaling solution in the water tank & continue descaling the rest of the machine by using hot water dispensing function, ½ cup at a time until the tank is empty. Finally, give a final flushing of machine to flush out remaining descaling solution inside the machine.
Services Unlimited Inc Parts Guru Since 1988
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edward_bbd2c7ff4ee1828a
Hi Carolyn Goode, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
