Question about Sylvania 6413TC 13" TV
Please Help I have a big sylvania tv that is like new, it has a vhs player and dvd player built right into it. When we turn it on it turns off by itself??
    Problem Solver:
  • 25 Answers
Hi channyfanny. Have you tried beating on the set, LIGHTLY!!!
After it has shut off??? If it tries to come back on when you do this, it may be a bad solder joint or cracked component in the tv, if not, it may be a faulty component in the shutdown circuit, or a high voltage problem.
Posted on Aug 14, 2008
Old Sylvania Trusurround SRS TV 4 head VHS and DVD combo, shuts off seconds after being turned on. No picture, just a black screen for a few seconds then it turns off.
good luck with that one I would consider buying a new system before wasting money on an old unit that will fail again sooner than later .
Apr 11, 2015 | Sylvania Televison & Video
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
I have a new vhs dvd player recorder that will not record.
please note in your vhs dvd manual it tells which dvd (maxell, tdk etc.)are compatible with the recorder
okay do you have a cable/satellite box connected to tv/monitor? yes or no
yes- is the the tv on ch 3? cable connected to cable box in, cable box out connected to dvd in,(on dvd set up menu make sure broadcast is cable) dvd out connect to tv... ? please note some dvd recorder will not record HBO (you can record on vhs tape)
no connect antenna to dvd in, dvd out goes to tv.....
hope this help...
May 20, 2010 | Quasar VHQ400 VHS VCR
My dvd/vhs combo has sound but no picture on the vhs side?
Check ur RCA cable setting might have a short in the cables.
Dec 12, 2009 | Televison & Video
VHS got jammed, clicks, turns self off
Open it up and next to the right spindal where the tape goes there should be a small, black B-S button, press it in with a pencil or pin, and it should reset the VCR's computer.
Feb 04, 2009 | Sylvania DV220SL8 DVD Player/VCR
DVD in, have sound but no picture???
Initially, a couple of ideas:
  • check the cables from the DVD to the VHS to the TV (I am assuming that the sound is likewise connected to the TV and not to a home receiver system or an amplifier);
  • I am assuming again that you are using RCA and not RF, if yes pls pay special attention to the yellow RCA on both the DVD to VHS and VHS to TV;
  • diagonal roll often indicates a loose ground or a defective cable/RCA connector;
  • verify settings/configurations in all three; DVD, VHS, TV. TV should be set to AV or Video, VHS likewise to A/V INput;
  • try playing a known good VHS tape, if normal playback, problem is between DVD and VHS, if likewise no video, problem is between VHS and TV.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Sep 13, 2008 | KLH DVD8350 DVD Player
New dvd/vhs player but old tv
The easiest thing to do would be get a new TV plain and simple sounds as if you could use one n e ways. But first make sure you are hooked up through coaxal to the tv that will allow everything to run on channel 3. Let me know your current hookup.
Dec 24, 2007 | Televison & Video
Error 2
my vhs/dvd combo sylvania shows error 2 how do i fix this
Nov 15, 2007 | Sylvania SRD3900 DVD Player/VCR
Sylvania SRDV495 DVD-VHS
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
Mar 06, 2007 | Sylvania SRDV495
HELP! I can't figure out how to Connect my Sylvania DVD/VCR Combo to my older TV
Even if you do get it connected you cannot copy from vhs to dvd as you have bought a vcr recorder with dvd player, not a dvd recorder. You can only record to the vcr tape from a dvd, in the players controls.
Feb 08, 2007 | Sylvania (SRDD495) DVD Player/VCR
Sylvania 6413TC 13" TV Logo
95 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
