Question about Canon NP 7130 Black and White Copier
Canon NP7130 copier
Good morning,
I just replaced the drum on my canon NP7130 copier. The drum is one I bought in the US (I live in Belize). AS soon as I replaced the drum, my copies came out blank. I carried the drum in my checked luggage, and am hoping that the xrays they use on the luggage did not ruin the drum. What do you think?
thank, Juli
  • Canon Expert
  • 270 Answers
Make sure that the black plastic arm just to the right of the gray drum release handle is in the proper position. This arm sometimes gets knocked out of position when engaging the tube of new toner. When the copier is clammed closed, this will sometimes come down on the right side of the post on the bottom front cover. This will move the developer far enough away from the drum to make blank copies. Hope this helps.
Posted on Nov 13, 2007
HOPW DO I INSTALL TONER FOR THIS MODEL NP7130
From the left sideway of copier you will see small "handle",pull it up and open the copier in right pulling her up.
Then on right side of toner tube holder you will see the handle wich you need to pull in anti clockvise direction, to remove toner unit from drum.
Rotate the toner tube clockvise and pull toward you.
Insert new tube, hold tube and pull out toner seal tape all the way out, rotate anti clockvise until its locked.Return handle in first position and close cover of copier.
Aug 04, 2010 | Canon NP 7130 Black and White Copier
Canon 210 S Message says to replace waste toner container - Where is it?
The waste toner is inside the drum unit it self. You can empty it out, but it is very messy. If it is full, you most likely will need a new drum unit soon. It is up to you.... Good Luck
Jun 03, 2010 | Canon imageRUNNER 210S Copier
I need a service manual for an Canon np7130
I found a service manual for this model. If still need it let me know.
Apr 08, 2009 | Canon NP 7130 Black and White Copier
Canon np7130 copier
Most likely when you make a copy you don't see the light scanning the paper, you can try this with the lid open to make sure. the Sacnning lamp is blown, need to replace
Jul 14, 2008 | Canon NP 7130 Black and White Copier
Black Copies
It could be a bad voltage board, which is not supplying enough power to the lamp.
Jun 30, 2008 | Canon NP 7130 Black and White Copier
Error code E000020-0181
Hello Brass, This error code means that the yellow drum/developer unit has failed. Your machine has 4 drums, cyan,magenta,yellow and black. At best they are good for about 40,000 copies. You can order one online and it is fairly simple to replace. Let me know if I can help further.
Jan 03, 2008 | Canon imageRUNNER C3200 Copier
NP7130 drum problem
hi im jules_09,you should not use compatible consumables for the copier sometime np7130 copier are nasty specially with opc drum,if the copy is blnk the problem is in the high voltage unit or in the transfer unit and drum charge unit you might have the wrong process replacing the drum.re install the drum then try it again .
Dec 02, 2007 | Canon NP 7130 Black and White Copier
Replace drum
hi im jules_09.at the packaging of the drum has a instruction that will show you the process in replacing he drum or just open the front door of the copier the drum unit has a lock for you to lit up just a small lever or 2 lever.after that you can easily full out the drum.just remember just dont let the drum before be expose to light it is sensitve to mit.5minutes is enough time for it to be expose morethan that the drum becomes deffective
Nov 05, 2007 | Canon NP 7130 Black and White Copier
Canon NP 7130 Black and White Copier Logo
236 people viewed this question
old marine
old marine
