why would you want to connect a hdd dvd to the strong decoder. Wouldn't you connect it to a television via the hdd dvd av output into the av input of the tv and then switch the telivision on input source to AV1 .
You did not mention the model number of the strong decoder but is this a digital tv to Analogue TV decoder.?
you might also have HDMI output and HDMI input on the devices .
That would be better to use if it exists. If you only have one AV input on the TV use a AV switch box and switch between the decoder and the HDD dvd device using
yes it is the ps3 is not reading the change tho so its an easy fix you just need to reset the connections i have done this alot on the front of your ps3 the power button press and hold it for 20 to 30 sec. it will beep a bunch then the connection is reset then try your new connections , the ps is suapose to read that but sometimes it don't it happens.
What kind of HDD do you have, do you have any type of output on it. You stated that you haven't connected the docking station to it and the TV...? The best thing to do is to connect your Archos to the Docking station. Set the docking station up correctly, with cables coming out of the HDD (if it has some sort of output) to the station and out of the station to your TV. Once you set that up, you can use the Archos as a mini DVR or VCR. Go to the REC option on the main screen of Archos, you'll have an option for Video Recorder (tab on top). If you play any source on the HDD, then all you have to do is press the Rec option on the Archos. If you already have a file on the HDD, then try just moving it over into the Archos once you connect the Docking station to your computer via USB or just use the USB cable connected to the computer with the HDD. I use the USB preference as Windows Media Device. (found under menu/settings/system). Is is basically a HDD itself. Remember the Archos will only play certain videos without the purchase of any extra plugins.
Good Luck
Connect your HDD Player to your Television (TV) or Monitor using AV Cable; your TV will become a full of AV Entertainment System.It is Capable of Downloading Files from your Computer,HDD Player can be act as your Mobile Hard Disk that Back-up your Important Files .It is Compatible with 2.5" IDE hard disk up to 500GB (not included) To computer :
Connect your HDD Player to your Computer using the USB2.0 output cable (cable provided); your HDD Player will become your External Hard Disk that will be managed by your computer Window Software ,Back-up your Important Files. But it need additional 2.5" IDEhard disk to work .
To TV or Monitor :
Your TV will become a full of AV Entertainment System after you connect your HDD Player to your Television (TV) or Monitor using AV Cable.Play movies,mp3 and view picture on TV directly,
Specifications:
It support NTFS and FAT32 formats
AV out to TV directly, VGA out to Monitor
When connected to your Computer, Do not connect your Power Supply
When connected to TV,it need power supply ( included,and which is compatible with your country)
Displays digital photos and movies on a TV, monitor without the use of desktop or laptop
Playable programs: MPEG4, Xvid, Divx, DVD,SVCD, VCD, JPEG, MP3,JPEG picture and MP3 song
Portable HDD function: USB 2.0 interface, windows management, be convenient for your study work and entertainment
Key button and Remote control operation
Supports TV type: PAL and NTSC
Audio outputs: stereo 2-ch (RCA)
Supports OS: Windows 98/98SE/2000/ME/XP
Portable design :132 x 80 x 19 mm
weight:215g
In the package comes: 2.5'' HDD player,USB cable,AV cables,remote control,manual ,power supply
