Question about Jenn-Air JFC2089HT Bottom Freezer French Door Refrigerator
JennAir refrigerator JFC2089HT
The fridge we just bought came with icemaker. We don't want to use this feature. Can it be removed easily?
Fred F.
  • 39 Answers
SOURCE: jennair french door fridge: freezer too cold,
i'll try to help w/out a model number but here it goes. more then likely your ice-mkr has stopped.right? if so turn ice-mkr off and it should help w/your freezing problem in the freshfood find out why your ice-mkr is not making ice. things to look for are water hook up or water turned off under the kitchen sink.
2. a cube stuck in the ice-mkr's ejecting teeth.
3. a defective ice-mkr. vist and input your model #,then choose ice-mkr to buy it. good luck
Posted on Jul 14, 2009
0 characters
1 Points
Jennair refrigerator jfc2089htb2
It is possible that the half side of your=> 67006531 Water Inlet Valve that controls water to ice maker is leaking like a dripping faucet and causing the problem. Can you see signs that water is flowing from the ice maker fill tube? The fill
JENN-Air JFC2089HT Water Inlet Valve Thanks John Tripp Appliance 911
Jan 23, 2014 | Refrigerators
Jennair jcd2289 side-by-side does not make ice
If you are getting water from the dispenser, then the water valve is good. The icemaker will need to be replaced since when the icemaker cycles and empties the ice tray, it should call for the water to refill and it is not doing so. Here is a link to the replacement icemaker.
Oct 16, 2012 | Refrigerators
Ice maker dont work
There are several things that can prevent and icemaker from working.
1- Temp in freezer. If the temp in the freezer is higher than 6 degrees the ice makers thermistat will not call for water.
2- Water inlet valve. If the inlet valve is malfunctioning the silinoid may not be opening. Even if you are getting water through the door.
3- Faulty ice maker. If the internal components of the ice maker are no longer functioning it wont make ice.
To test the inlet valve. In the back of the fridge is and access panel near the bottom remove this panel and look at the inlet valve. now you should see 3 hoses. One is usually copper and runs directly from the house water supply. There will be two other hoses from the inlet. One leads into the fridge for the water in door feature. The other is for the icemaker. Switch the two hoses from the ice maker ( water in door and icemaker) than push the water in door feature and see if the water goes into icemaker. If it does not than replace inlet. If does and temp in freezer is below 6 degrees replace icemaker.
If you need further assistance please comment me back.
Jul 30, 2011 | Kenmore 53642 / 53644 Side by Side...
Filter light is on "replace".
Hello, Thank You for using FixYa. I will be helping you today. The water filter is in the top right corner of the fridge.
Thank You and please rate my answer if it was helpful..
Jun 22, 2011 | Jenn-Air JFC2089HT Bottom Freezer French...
We have a KitchenAid Side by Side Refrigerator (KSRA25C). The ice maker will not work. We have replaced the "in the grill filter" water valve, but that didn't fix the problem. All other features of the...
Pour about 1/2 cup of water into the icemaker . If it dumps then water valve is the problem . If not , then icemaker is the problem . Make sure the laser switch on r/side of freezer is on . and the coils at the bottom of fridge are clean ( icemaker must be 5 degrees to operate ).
Jul 18, 2009 | Refrigerators
Whirlpool fridge icemaker stuck upside down (side by side fridge)
it seems the ice maker cam asm is broke it will have to be replaced
Dec 20, 2008 | Refrigerators
Jenn-Air JFC2089HT Bottom Freezer French Door Refrigerator Logo
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Richard Roth
Richard Roth
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
