Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher
Problem for Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level...
Water won't drain
By rrr0 on Jul 07, 2009
water won't drain
Solution #1
posted on Jul 07, 2009
Not Rated)
VtToolMan
Rank: Guru
Rating: 97%, 598 votes
First check that there isn't anything blocking the drain area inside the bottom of the dishwasher. Sometimes plastic wrap, a small Tupperware, etc. top gets sucked against the drain and blocks discharge. If nothing is there, (look really good, by getting out as much water as possible!!!). If nothing there, see if you have an "air-break" installed at the kitchen sink, this prevents backflow from the sink drain back into the dishwasher, check it by removing the decorative cover and see if it is clean and has no obstructions blocking water flow.
Another thing to check, is if you recently had a new disposal installed, it's possible that the dishwasher inlet was never "punched out" to allow for the dishwasher to drain thru the disposal. If none of those, continue with the investigation!
Check to see if some broken glass might have worked its' way into the drain area, beneath the drain discharge guard. You'll have to remove the cover, some are just clipped in place while others have a screw holding them in place.
If still nothing, it is possible that something has worked its' way all the way into the discharge pump section and you'll need to remove the dishwasher from under the counter to get at the pump section.
Normally when the dishwasher is in the pump out sequence, you can hear the pump motor and impeller spinning, if you can't, then proceed with removing the dishwasher and disconnect the power or shut off the breaker to it. It is quite possible that something has jammed the discharge impeller and is preventing pump out. Again, if you can hear the motor and impeller running, it could still have an obstruction. Bucket and towels will be needed to soak up all any water that you couldn't remove before pulling the dishwasher out from under the countertop.
If there is no obstruction in the discharge pump section and the discharge value (usually a simple rubber flap) is moving freely, then it could be the pump out solinoid (an electronic valve that opens the discharge port for pumping out water when the dishwasher is done washing and is signaled to drain. You should be able to cycle the dishwasher through a short cycle (wash & rinse) to see if everything is working. You'll need to restore AC power and have the water line turned on for this. If you don't see or hear the valve open up when the wash cycle is over, then it could be this part that has failed.
Was this helpful?
Yes
No
Popular Solutions for Electrolux Kenmore 24 in.
Questions and Unsolved Problems for Electrolux Kenmore 24 in.
Do you recommend Electrolux Kenmore 24 in. Built-In Dishwasher with 5-level Precision Direct Water Delivery System Dishwasher?
Answer
Answer
The # on the washer is 3850DD3006A. 3 minutes into wash cycle it starts beeping and shows IE
Answer
top spray arm does not rotate, it is mechanically free to rotate
Answer
Dishwasher wont drain . After the cycle is done the water is still in the machine.
Answer
when dishwasher is turned to the start position, water will fill to about six inches and the machine... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Electrolux Kenmore 24 in....:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 905-9505
A&E Factory Service is a nationwide leader in...
A&E factory service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
