Question about Motorola Mobility L6 Cellular Phone
Wont charge or is locked
My battery was dying, was not getting a good connection to charge it in the car. Tried a couple times. Finally got home to charge with my wall charger and phone was turned off. Thought the battery just plain died enough not to turn on until charged again. Charged over night with my wall charger and next morning, still looks like it is charging, but won't even power on, etc. removed battery several times and tried to power on again, etc... even did the removal of battery, hold power button for 30 secs then put battery on and tried to power, still nothing. Any suggestions?
  • srimanoj85 Nov 16, 2007
    i not getting software to install and to enable usb charging
  • Anonymous Mar 14, 2014
    I charge it over night and then the next day I will still have to charge it during the day. What can I do?
  • 4,102 Answers
If you plug the charger in and you can see the battery bars going up and down then it is phone problem if the scrren is blank then it is either the charger but if you have a car charger aswell and both chargers worked before then it is probably the phone that has a problem check where the charger plugs in that their is nothing blocking the terminals like fluff or bit of paper check that none of the terminals are bent or coroded if you have used phone in rain they might have got coroded this can be solved by cleaning the terminals on the charging part of the phone but be carefull when you do this not to wreck any thing check the charger make sure nothing bent or blocking the charge the problem with these phone is the pins on the bottom where the charger plugs in these get damaged really easily and they can be replaced but will have to take to phone shop and get repaired hope this is some help to you....................................
Posted on Nov 15, 2007
2001 Bravada wont start. turn key all lights and gauges come on but starter is silent. not even a click. tap on starter it starts. 12 v at battery. whats wrong?
replace the starter as you have a armature/commutator problem
have it checked on the bench at an accredited auto electrical shop commutators/armatures can be bought separately to reduce cost of new starter
Apr 18, 2015 | 2001 Oldsmobile Bravada
2000 subaru forester wont start battery is good what can I check next
Do headlights work? Do they get dim when you hit the start position, if so battery has bad cell.
Bad batteries might be OK after charging and running the car for a time but will discharge after car sits for maybe longer than a half hour. Usually a bad cell.
Take to auto parts store, they will load test it for free.
Mar 01, 2015 | 2000 Subaru Forester
Pontiac sunfire died while driving gauges stopped working
Where did you buy the alternator? Charge the battery and have them both tested.
Apr 01, 2014 | Pontiac Sunfire Cars & Trucks
Battery wont hold charge, and battery is good
Check/repair, clean connections, charging system...
May 18, 2013 | 2001 Suzuki GSX 1300 R Hayabusa
Battery died, charged it took it for a drive half way back home dashboard lights went out heater also went out van almost died, when we finally stoped to park turned it off then decided to try again and...
Take your battery in for testing after charging it. Then, to avoid pulling the Alternator for nothing, drive to a local Autozone, Advance, or Oeilys and ask them to check your charging system on the Van.
Consider taking an extra battery if you have one to fit, so you can get back home after the test. Run the van with the charger connected until you get good heat, then reduce the blower fan speed to minimum. Then disconnect charger.
If you are still stuck on the road, jumpstart the van until it is warm, using the jump car to charge the battery so you can go home and try again. Just leave the battery jumpers connected to the struggling van battery a few minutes so the old battery has a chance to charge.
Jan 19, 2012 | 2000 Ford Windstar
My black 360 controller with a rechargable battery, has been having 4 major problems, 1. It started disconnecting while playing Halo Reach and after. 2. My controller was not able to charge any...
Rechargeable batteries will only hold so many charges before they finally die. The controller should be fine, but your battery pack has finally died. You can get new rechargeable packs on Amazon pretty cheap, but don't buy any that seem too good to be true (like the $0.01 ones) because they are old inventory and have lost the ability to charge as well.
I think they run about $15-$20 for a new one, but it's still a better deal than needing new batteries every time your controller dies since the rechargeable ones can last for at least a couple years.
Jul 23, 2011 | Microsoft Video Game Consoles & Games
Our car just dies out all of a sudden and it sounds like the car wants to start. Then we boost it for awhile maybe 30 mins to an hour to finally start then it will start good for a couple of days. Then do...
Its dying because the battery is not being charged, and it takes power to run the ignition pak to run motor and electrical systems. I would have the alternator checked out as that seems to be the most obvious problem,only other solution is battery will not take a full charge. usually if the alternator is charging it will supply the power to run the car, but if the battery wont take a charge then it will not have enough power to start the car or run the voltage that the ignition needs to operate. solution is bad battery or bad alternator.
Jan 13, 2011 | 1997 Dodge Neon
2000 beetle battery
Sounds like your battery, have you had it heavy discharge tested ?
Get the alternator charging rate tested if battery tests OK.
Good Luck !
Please give a FixYa rating !
Feb 04, 2009 | 2000 Volkswagen Beetle
2006 Tuscon Battery Dies while Parked--randomly
It is the Alternator. The Battery will Charge But drains while Driving. The Alternator is not Recharging the Battery while the Motor is Running.
Jan 21, 2009 | 2006 Hyundai Tucson
Engine keeps dying
Time to switch to a low consumption car my friend
You are financing Terrorist countries such as Syria and Iran!
Jul 14, 2008 | 1998 Nissan Frontier
Motorola Mobility L6 Cellular Phone Logo
187 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
