Remove spark plugs, need to gap new ones
Page 69 of the user manual: http://www.yamaha-motor.com/assets/service/manuals/2012/2012_Vector_LTX_Venture_GT_LIT-12628-03-03_1912.pdf
1. Push STOP switch down.
2. Remove air cleaner cover.
3. Disconnect the wire connector (G) from the spark plug
(H) by pulling and twisting at the same time (Figure 7-
5A).
4. Remove spark plug with spark plug socket wrench.
DO NOT USE ANY OTHER TOOL.
5. Check electrode gaps with wire feeler gauge and set
gaps to .025" (.635mm) if necessary.
6. Reinstall a new spark plug.
Here is the manuel with pictures as well:
http://pdfservicemanual.com/home-appliance/2006-2008-mcculloch-mcc1435a-mcc1635a-mcc1635ak-mcc1435a-ca-mcc1635a-ca-mcc1635ak-chainsaw-owners-service-manual.pdf
If you're replacing the spark plugs in your car
engine, you'll need to set the gap before reseating the
spark plug. The gap is the distance electricity arcs between the ground
electrode and center electrode. The gap must be set correctly to ensure
maximum performance. Here's how to set the gap of a spark plug.
