Question about Panasonic NV-GS15 Mini DV Digital Camcorder
Playback problem on Panasonic NV-GS15
Getting black horizontal stripes when playback. Can it be dirt or ????
  • 6 more comments
  • danny wilkinson Nov 12, 2007
    i too get black lines across my screen when playing back my footage. i tried a head cleaning tape and it worked for a few times but now has no effect.
  • Seelan Nov 18, 2007
    I have a Panasonic NVGS15. When i playback i get black lines on the screen and the picture is playing back faster than normal. The problems seems to be with the playback of LP and SP casettes. Please send me a solution
  • Anonymous Dec 25, 2007
    I have this same problem, I used a cleaning tape and its seems it worked but then they were fixed in playback, sometimes the stripes are grey, any solution ? by the way my camera is a canon zr 700, It has to be the head of the camera I guess !!!
  • tazzbuster Jan 05, 2008
    My camera has all the black lines during playback also it is asking me to press the reset button as well .Will cleaning the heads work with this?
  • lauraliann Jan 10, 2008
    Same problem, play back with lines, and no sound. But sometimes it's fine... at others, if I stop and start it again, same problem. The problem seemed to begin right after a borrowed a tape from someone else that might have been dirty. Do I need to worry about reusing the same tapes I've tried to play unsuccessfully after cleaning? Or are they now permanently dirt contaminated?
  • md650 Feb 19, 2008
    i have nv gs 15 mini dv digital camcorder. i get black horizontal stripes when i playback. i tried the head cleaning tape , it worked fine for two minutes and then again the same problem. please help as i have to convert my tape into a cd for an important occasion
  • Anonymous Feb 25, 2008
    black stripes across the screen.
  • Alexxxx Mar 08, 2008
    Gentlemen, I had the same problem, my fix is a little ridiculous, you need to punch your camera, it solves my problems, the pictures get clean again... good luck
    Problem Solver:
  • 5 Answers
It is probably a dirty head. One camera i had i had to clean it much more often that i wanted to and certainly before any important shoot.
Here is a tip though. Always use the same make of tape (and code). If you do change your tape (or code) then clean the heads before you put in the different tape. this is all to do with "dry or wet" lubrication used on different tapes. i do not know enough about that to comment, but the tip comes form a very good source.
Some people run the whole tape through on record (with the lens hood on) before they use it. I do not think it will help for this problem, but you can try.
Posted on Jan 01, 2008
Horizontal equally spaced black bars accross the screen when in playback mode similar to looking through partially opened venetian blinds.
You may need to clean the head on the device. You can purchase head cleaning tapes from most stores that sell the tapes, or goto a specialist camera shop.
Failing that, open the tape slot, tape the tape out, and with a soft cloth see if you can clean the small silver heads very gently.
Oct 20, 2010 | Panasonic NV-GS15 Mini DV Digital...
Please, I have a kind of digital Kamra PANASONICE NV-GS15 I want a program to read on your computer
To get the videos on your PC you will need a firewire cable to connect (USB is not working for videos on this model). plug it in, Open up windows movie maker, click 'capture from video device' Choose your cam, Click next, Choose best quality, Make sure ur cam is set too playback mode, Click play on your cam and start capture then click stop capture when finished. No other software is required.
Oct 09, 2010 | Panasonic NV-GS15 Mini DV Digital...
My screen is striped blue during playback with no soud panasonic palmcorder pv gs15
Your tape has a small latch on it that closes to protect from recording or eraser and opens to allow for playing or dubbing. Slide it open and see what happens.
Sep 25, 2009 | Panasonic Palmcorder PV-GS15 Mini DV...
Black Bars
Try re-setting the camera by pushing the reset-switch with a small object (like a pen).
Apr 16, 2009 | Panasonic NV-GS15 Mini DV Digital...
No color
Do you have a replacement cord between your tv and camcorder that you can try?
There probably is a short in the yellow cord causing the picture to go to B & W.
Aug 19, 2008 | Panasonic NV-GS15 Mini DV Digital...
Black lines on playback no playback
hi, if you have stuck the head cleaner in and this has not removed the black lines then the head might either need a thorough clean or may be damaged.
Jul 03, 2008 | Panasonic NV-GS17 Mini DV Digital...
Panansonic NV GS15
same thing happened for me. Helped resetting the cam.
Apr 06, 2008 | Panasonic AG-DVC30 Mini DV Digital...
Choppy recording and playback
If the heads become dirty, “NEED HEAD
CLEANING” appears during recording. During
playback, moreover, the following symptoms
≥Mosaic-like noise appears partially or the
sound is interrupted.
≥Black or blue mosaic-like horizontal stripes
When normal playback cannot be performed
even after the head cleaning
One possible cause is that normal recording
could not be performed because the heads were
dirty at the time of recording. Clean the heads,
and perform recording and playback again. If
normal playback can be performed, the heads are
clean. Before an important recording, be sure to
conduct a test recording to make sure that normal
recording can be performed.
≥If the heads become dirty soon after cleaning,
the problem may be the tape. If so, try another
≥During playback, the picture or sound may be
interrupted momentarily, but this is not a
malfunction of the Camcorder. (One possible
cause is that the playback is interrupted by dirt
or dust that momentarily adheres to the heads.)
Mar 27, 2008 | Panasonic PV-GS150 Mini DV Digital...
BLACK Lines and having to reset.
i assume that the 'black lines' are 5 bars of dark video spaced equally across the screen. this is a symptom of dirty heads. use a mini DV cleaning tape, and the problem should go away.
Jun 09, 2007 | Panasonic NV-GS15 Mini DV Digital...
Panasonic NV-GS15 Mini DV Digital Camcorder Logo
413 people viewed this question
Top Panasonic Video Cameras Experts
Kenneth Walker
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Panasonic Video Camera Expert? Answer questions, earn points and help others
