1586,1550,1539. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Type in the brand name of your device, in the search box [at the top right] of the display window, and press enter to get all related posts. It will make surf easy.
SOURCE: i have a philips universal cl035a remote.i need
In the manual it say's that what you need to do is hold the code search button untill it stay's steady then press the function button (TV, cable or whatever) for the device you need to program before doing this though turn the TV or whatever on first. Then go to the chanel select up or + button and continue to press it until it changes channel if you over shoot it you can press the - or channel down button.
When you are were you want to be quickly press the mute button and release ( warning do not hold the mute button just press it quickly and release.) This will set the remote to the corect code.
SOURCE: i need remote codes for the philips universal
www.universal-remote.net
www.remotecodelist.com
SOURCE: I need Philips CL035A codes list for toshiba tv
I believe this is your remote. it's listed as pm435s
http://www.p4c.philips.com/files/u/us2-pm435s/us2-pm435s_dfu_eng.pdf
these are the codes for toshiba
0517, 0419, 0512, 0613, 0719, 0112, 0506, 0111, 0618, 0627, 0437, 0041, 0094, 0802, 0111, 0313, 0715
