Lance Ling Posted on Feb 04, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AR5731 Undetected few months ago a both my copier machine after number of print i need to replace my toner a technical guy offer me refill toner because the price is lower than the original toner so i was convince this technical guy made some adjustment on the machine so the refill toner work after few months i need to buy new toner i am trying to call this technical guy but i can no longer contact him so i buy a brand new original toner cartridge unfortunately the toner can not be detected by the machine i ask the supplier about this and their reply i need to ask the technical guy to return what he did with my machine unfortunately i can no longer contact this technicl guy anybody can help me o reset this machine so taht it can read new noercartridge
sahoo_sanjay
Level 3:
Master:
  • Office Equip... Master 553 Answers
  • Posted on Feb 04, 2015
sahoo_sanjay
Level 3:
Master:
Answers
553
Questions
0
Helped
218898
Points
1676
Dear
The refill guy may done somthing which by pass the CRUM chip. At your end you may check the module attached to the toner cart.and test with alter that chip.
This may solve.
Before doing this pl.check the errorcode display .there might be other related problem with the machine.
Thanks.
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on May 21, 2006
SOURCE: HP k80 will not print yellow
spounds like a defective print head bud. these do wear out and most of the time it will cost as much as a new unit.. Good Luck
Soulvisitor
Soulvisitor
  • 1113 Answers
  • Posted on Dec 22, 2007
SOURCE: I have an end of toner life situation on my brother 2040. Can I cheat a few more prints out of it until the new refill arrives?
I dont recomment you use non gen toner, it will cause problems, but cause it is xmas ..... left side of toner cart is reset assy, examine it, there is a lever that falls back once new cart is inserted, this lever need to be placed in 10 oclock position now it at 3 oclock, 3 screws carefull removal and reset into position.
Warning useing a toner longer than it was ever designed for can and probally will damage the drum, powder will run out, developer roller will make direct contact with drum surface and scratch it.
gadgetboy21
Rugeshan Lanka
  • 15 Answers
  • Posted on May 13, 2008
SOURCE: Lexmark Z816
it is most proberly that the cartridges are damaged now due to the refilling because certain cartridges can't be refilled and some can bt are limited to the amount of times that you can fill them so you might have to go out and buy new cartriges but try this 1st. remove the cartridges and use alcohol or spirits on a soft cloth and wipe the pins on the head of the printer and also on the cartridge were the pins would make contact to the cartridge these should be copper in colour.
Paul Hutchinson
  • 909 Answers
  • Posted on May 08, 2009
SOURCE: refilled cartridge, still says it needs to be replaced...
If you let the cartridge run totally dry then they need to be reset or replaced, I have tried purchasing reset software myself and found then to be a waist of money as they do not reset the cartridge at all. Do yourself a favor and replace the cartridge and remember to top up the cartridges before they get half empty.
Anonymous
  • Posted on May 13, 2009
SOURCE: Brother HL-4040CN won't read or show new refilled cartridge in the LCD
I think I know what the problem is...
When you refill these toner cartridges you need to reset the "toner empty" cog wheel.
For instructions on how to do this follw this link:
http://www.proprint.co.uk/brother_hl4040.htm
It has pictures and explains how to reset the cartridge
Good luck,
Billy.
Just replaced toner K and now says empty
You replaced the Cartridge with a OEM product or third party or a refill. if the last the electronic chip on the toner cart is still telling the machine the cartridge is old so refilling will never work replace the cart with OEM cart,
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Refilling toner in xerox phaser 6280
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing thetoner cartridge and shaking the toner cartridge in a horizontal position a fewtimes and then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your model printer.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
How to refill toner manually
I would not advise you to refill a toner cartridge becausethe toner powder is very fine and you do not want to breath in this tonerpowder.When the toner cartridge is exhausted or empty then theprinter will not be able to print further documents or the prints will be veryfaint.You may be able to print a few more pages by removing the tonercartridge and shaking the toner cartridge in a horizontal position a few timesand then placing it back into the printer.This will give you an opportunity to print a few more pages and giveyou time to purchase a new toner cartridge for your printer. A cheaperalternative is to purchase a re-manufactured toner cartridge for your modelprinter.A re-manufactured printer cartridge also replaces worn partsas well as refilling with toner powder.
1helpful
My samsung ML 1640 Laser printer exhibits "Toner Exhausted, Replace Toner" after refilling the toner
There is a chip on the cartridge that knows how many prints you have done. The refiller guys know this. Take it back and get another.
I was used samsung scx-4300 printer used refilling cartridge printed some print then shows low toner then after some prints they shows toner exhausted replace toner my mail id is [email protected]
Good day,
To order Samsung-Authorized toner cartridge contact your local samsung dealer or retailer where you purchased your machine, or visit www.samsungprinter.com and select your country/region for information on calling for technical support.
have a nice day!
Poor print quality
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink or toner cartridge?
Please consider the following:
If you are using a refilled or third party cartridges that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks or toner causing problems with print quality or damaging the physical printhead or photo conductors.
If you are using factory new ink or toner cartridges, then please call the manufacturer’s Technical Support for assistance with the warranty on the cartridges
Don
Want copier to use up more toner in machine
If you know where the "Toner Eye" is in the copier, cover it with black tape. Usually though, the copier counts the number of pages printed and then at a predetermined number thinks toner is low and stops printing. If the toner cartridge is chipped (has a electronic chip) it keeps the count in there. These type of cartridges are refillable, but still have the "Empty" count. The counter must be reset. These resetters are hard or impossible to get.
1helpful
The pages that print are dark with toner all over the paper.
Barb,
1) if you are refilling the toner cartridge, it may be the blade and roller need to be replaced.
2) if you are using a high yield cartridge, the drum unit will need to be replaced every 2 1/2 cartridges.
The yield for the drum unit is every 20K pages. The drum unit may also be remanufactured.
Copier won't print after refilling toner cartridge
As far as I know, filling up with toner is not enough. There is an electronic chip that must also be replaced, so the toner cartridge tells the unit it is a new one. Check with your supplier for such chip.
k24674
ADMIN Andrew
ADMIN Andrew
