If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
SOURCE: 42" Philips plasma screen goes black
You have a Ysus problem. Sounds like a cold solder joint or loss connections on ysus main board.
SOURCE: I have a Phillips 42
I wanted to share my solution to this problem. Not only is it an easy fix (aside from taking the tv apart) but it also explains some of the strange methods I've read that have worked, such as taking out padding from behind the boards or putting a magazine under one side and even tapping on the tv for a temporary fix.
Granted its only been a few days of it working but I tell you this....It's not done the half black screen once! And trust me when I say it was doing it constantly.
Ok so first off the problem definitely lies in the upper/lower buffer boards. On the model mentioned by the OP (same model I have) it's located on the same side as the power button (right side when you are looking at the tv).
Ok so you've got the tv openned face down on a non static surface. Btw I was shocked at how many youtube videos I found of ppl working on their tvs while its laid flat on their sofas!
When you are looking into it you will see on one side there are two vertical boards hooked up to another board more towards the center. These two boards are your upper and lower boards that provide the upper and lower picture. The problem I was having was in the lower section of the tv going black so obviously that corresponded to the lower board. (They are labelled upper and lower if you look closely)
So here is what I did:
I noticed the lower board was not sitting flush so I unscrewed the one screw on the bottom and noticed how much of a gap was in the screw hole. The problem was it was screwed down in such a way that one of the connections going to the main board was not making it's proper connection. So I just gave it a little push towards the center, held it, and screwed it back down.
That's it! It's fixed now. No need for replacing anything. Just poorly drilled holes and a few things not lining up correctly!
So hopefully anyone else that's having this same problem might have some luck in using this fix. Good Luck!
SOURCE: Black line on Panasonic Plasma
go here and follow, it will work!
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
SOURCE: Vertical white line down centre of Soniq PT42SH plasma TV.
One of your "X" buffer boards is defective. In Panasonic plasma tv's they are located at the bootom of the set and connect directly to the plasma diplay panel via a thin ribbon cable. The board you want to replace will be directly in line with the discolored vertival line in the picture. The part number is on the circuit board and usualy starts with "tnp..." or "txp..."
SOURCE: 42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
