Question about Sony KP-51WS500 51" Rear Projection Television
Colors out of alignment; curved lines
In a comment a guy said he aligned the tubes/projectors manually (or was it the lamps?). i cannot align the colors with the three screws. do i need to align the tubes manually? how do i go about it?
  • rrr925 Nov 12, 2007
    thank you very much, terryfic. saved me from trashing my tv...or from a shock.
  • Bizz50 Nov 15, 2007
    Colors out of alignment Cannot Converage
  • 1,694 Answers
Please stop where you are! Expert technicians rarely align manually = only when CRT changed or someone tries to
correct an electronic anamoly mechanically........
Curved lines are caused by defective IC's = STK392-560....
Found mounted to heatsinks on " G " PCB.........T.
Please rate solution offered and ask for more help, if needed.
Posted on Nov 12, 2007
It seems that the lcd panels are failed
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jan 26, 2014 | NEC Lamp for VT460K Projector
Marilee, you will need to check on the service manual schematic of what types of voltages you have on the IC's now. Most of the time, there are whats called pico fuses that blow out when the convergence IC's blow out. They are located on the G board, and are yellow in color. They look like small resistors. Check them for continuity after you replace the IC's. By the way, did you use good replacement IC's for the convergence? There are all sorts of aftermarket types and factory rejects being sold out there via the web or from local electronic parts distributors. Make sure they are the original types. If you know how to read a schematic diagram, but do not have the service manual, let me know, leave an e-mail address, and I will be happy to send you some info on the replacement of the ICs as well as the factory service manual. Good Luck!
Nov 25, 2007 | Sony KP-51WS500 51" Rear Projection...
Red haze at bottom of screen
Shut down the projector and allow time to cool before the lamp is taken out to be examined for any dis-coloration. If so the lamp needs to be replaced, try to test using a leased lamp to confirm Also check for shift in the alignment of the lamp settings and also the Lamp alignment.
Dec 15, 2011 | Epson PowerLite Home Cinema 8500UB...
My RCA P52937SG projection tv. Picture distorted. I beleive it has to do with the green circuit / projector. Everything needs to be aligned to green. Green projector is on, but, in alignment screen I get...
The tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?The tv convergence board is dead.The tv convergence board must have replace the 2 STK convergence ICS and some or all of it resistors too.To fixed the tv convergence board to solved the tv convergence picture problems.The shop,will cost u like $300-350 for parts and labors.
Mar 28, 2011 | RCA R52WH73 Projection Television
Green line on left side of an image and a red line on right. Such as around a face. Colors just don't line up and picture is very fuzzy. Had another old rear projection and it had a way to align it. Can...
Your other model was more than likely a CRT projector where you coulod manually align the Red/Green/Blue guns. The one you have now is more than likely an LCD projector which can't be readily aligned. Sounds like the panel is failing.
Mar 13, 2011 | Zenith R57W46 57" Rear Projection...
My screen has little dots appearing sometimes red sometimes blues behind the picture i just replaced the lamp bulb as i thought it would cure the problem
the projection tube needs to be adjust for color alignment, each tube (red, green, blue) must be aligned so you there would be no color smear appear on screen. if it is aligned try to set up the color balance, hue etc.
Feb 06, 2011 | Samsung Televison & Video
The red and blue projectors aren't aligned with the green projector. It is more sever towards the top of the screen. The green projector also has a curve in it at the top of the screen.
this is called convergence.
the set should normally have a function in the menu to adjust/reset this.
it sound like either the mirror in the tv is warped or the green lamp is out of alignment. if the convergence in the menu doent work then its a service job.
Feb 07, 2010 | Hitachi 61SWX10B 61" Rear Projection...
Picture alignment is off and the bottom and top are cut off
That guy explains the different adjustments on a T.V.
I'm not sure if you want the colors aligned of the general heightwidth adjustment.
Be sure to watch this also,shows how to safely discharge your set, it's a safety precaution that can't be overlooked.
Feb 21, 2009 | Sanyo DS20425 20" TV
Color shift
Hi there
There is unfortunatelly no section in the Service Manual to explain this sort of procedure.
You'll have to move the LCD panels one by one - millimeter by millimeter.
Mar 29, 2008 | InFocus LP290 1100 Lumen XGA LCD Projector...
Projection red is above other colors
Look in your menu for something called "horizontal static convergence" or just "convergence". Adjusting this will align all three tubes electronically. If physical adjustment is needed, then you have to do this manually inside the Tv. keever
Dec 09, 2007 | Mitsubishi WS-65908 TV
Sony KP-51WS500 51" Rear Projection Television Logo
127 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
