Question about Cell Phones
No ringtone When receiving a phone call my Samsung SCHA850 only vibrates and I don't have any ring tone.
Re: No ringtone
  • 67 Answers
Re: No ringtone
What you have to do is to go your nearest service provider ask him to replace the ringer speaker for you or you check the settings of ringing style.advise by dogy
Posted on Dec 21, 2007
0 characters
3 Points
I want to take off the ring silencer on convoy 3
I use Convoy 2. Go to "Setting" and select "Sounds settings".Select "Call Sounds" and select "Call ringtones". Then select "Call ringtones". Find "no ring" if you see it just select the ring tone you want and test the ring tone. I hope it is work for Convoy 3.
Sep 28, 2014 | Samsung Convoy Cell Phone
When i recieve a text message there is no ring tone or vibrate
plz check your sound setting.for that
instructions are:
1. go to your phone's "setting".
2. enter into "sound".
3. "ok" or "click" on "vibrate".
4.and if you want ringtone at received time than go to "phone ringtone" below vibrate option.
Aug 17, 2012 | Samsung SGH Cell Phones
How do you adjust the volume on the Samsung T255 StraightTalk phone?
Sound Settings
You can customize various sound settings.
Incoming call
Note: When downloading MegaTones® or HiFi RingersTM, charges may apply.
This menu allows you to select a ring melody. Highlight Ringtone and press . Use the Up or Down key to highlight a ring tone or press the Left or Right key to select a file from either the Default Melodies, Voice list, or Sounds folders. Press the Select soft key.
This menu allows you to adjust the ring volume to one of 7 levels plus Silent mode and Vibration mode.
  • Use the Right or Left key to increase or decrease the volume.
Alert type
This menu allows you to specify how inform you of incoming calls. Use the Right or Left key to select an Alert type.
The following options are available:
- Melody: the phone rings using the ring melody selected in the Ringtone menu.
- Vibration: the phone vibrates but does not ring.
- Melody and vibration: the phone rings and vibrates simultaneously.
- Vibration then melody: the phone vibrates three times and then starts ringing.
- Melody then vibration: the phone rings using the ring melody selected in the Ringtone menu and then vibrates.
Message tone
This menu allows you to set up the ringer for incoming messages. You can set the Tone, Alert type, and Repetition.
  • Use the Up or Down Navigation keys to make your selections.
Keypad tone
This menu allows you to select a Beep or a Xylophone for your Keytone and to select the Volume (0-7) that the
phone sounds when you press a key.
Jan 25, 2011 | Samsung T239 Cell Phone
How do you put on the ringtone on this phone?
Follow this
  1. Press the left soft key for Menu
  2. Choose Settings (9)
  3. Choose Sound settings (4)
  4. Choose Ring tone (1)
  5. Choose the desired ringtone and press the left soft key for Select
Refer this link for all the setting for ur phone..
Hope this helps
Good Luck:-)
Jul 09, 2010 | Samsung SGH-e315
How do I turn off the key pad tone on the impression sgh-a877
The Sound Profile only covers call sounds.
Sound Profiles
This menu allows you to specify how you are informed of
incoming calls.
Selecting a Profile
1. Touch ➔ Settings ➔ Sound Profile.
2. Touch the radio button next to the profile name. The
selected profile activates. Choices include:
• Normal
• Silent
• Driving
• Outdoor
Normal Profile
The phone’s profile defaults to Normal. Use the following
procedures to change the profile.
Editing the Normal - Call Profile
1. Touch ➔ Settings ➔ Sound Profile ➔ Normal.
• Touch the name field and not the radio button to the right.
2. Touch drop-down menu (upper-right of the screen) and
select Call.
3. Select the Call Alert Type field and select one of the
following and touch Save:
• Melody: the phone rings using the ring melody selected in the Ring
tone menu.
• Vibration then Melody: the phone vibrates and then starts ringing.
• Vibration & Melody: the phone vibrates and plays a melody
4. Touch the Voice Call Ringtone field, touch to select a
ringtone and touch Save.
5. Drag the Ringtone Volume slider to the volume level you
desire (range is 1-7).
6. Touch the Vibration Pattern field, then touch to select
Vibration 1 - 5.
7. Touch Save to return to the Sound Profiles menu.
There is no mention of keyboard tones in the user manual.
Mar 19, 2010 | Samsung SGH-A877 Impression Cell Phone
Ring vs vibrate
This phone allows you to independently set ring and vibrate modes. When you access "Call Vibrate" to set the mode, also visit the "Call Ringtone" menu to turn off the ringer.
You may want to leave the vibrate mode OFF and your ring tone ON and use the quick keys to switch between ring and vibrate. Two ways to do this, push and hold the # key to switch between normal mode (the settings you chose in "Call Ringtone" and "Call Vibrate") or use the side volume button to access the "Master Volume" and select "All Off", "Vibrate" or a ring tone volume.
If this helps you, please leave me a good rating.
Aug 17, 2008 | Samsung SCH-u340 Cellular Phone
Ringtones on my moto krzr
did the tones come pre installed on the phone? why dont you try using mp3 ring tones? download mp3 songs on your phone, then you can set them as ring tones. they work much beter than ordinary ring tones
Jun 08, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
No ring, only vibrate
if the ringtones ring from settings or the songs play then it will be surely the settings problem please select ring and vibrate instead of vibrate only and if it doesn't works then go to a near by repair shop and ask them to check and change the buzzer
May 02, 2008 | Nokia 6288 Cellular Phone
6600 ringtone
go to Profile in Menu
select outdoor
options- personalise
set to------
Ringing Tone-  any ringtone u want
Ringing Type- Ringing
Ringing Volume- Full
Message Alert tone- any tone u want
Vibrating Alert- on
keypad Tones-__________
Warning Tones-_____________
Alert For-_________________
Profile Name-_____________
Mar 25, 2008 | Nokia 6600
Can't hear ring tones. Vibrator works fine
turn of the vibrator mode
set on restore mobile settings and try
Jan 11, 2008 | Motorola Mobility V557 Cellular Phone
Cell Phones Logo
162 people viewed this question
Top Cell Phones Experts
IT Solution
IT Solution
Are you a Cell Phone Expert? Answer questions, earn points and help others
