2009 Chevrolet Equinox Logo
D
DAVID BISHOP Posted on Feb 03, 2015
Can you tell me which relay is for the horn on a 2009 Equinox
I have only looked in the Operators manual.
MrDylan
Level 1:
New Friend:
  • Contributor 21 Answers
  • Posted on Feb 03, 2015
MrDylan
Contributor
Level 1:
New Friend:
Answers
21
Questions
0
Helped
1844
Points
82
Are you looking for the part? Would be RY280T I think.
Tonhei B. Benson
Level 1:
New Friend:
  • Contributor 39 Answers
Tonhei B. Benson
Contributor
Level 1:
New Friend:
Answers
39
Questions
Helped
21793
Points
75
The accessories fuse should be the one
sherryann perry
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 10, 2015
sherryann perry
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
206
Points
Iam looking to change the right sesnor on my 2009 equinox
2helpful
2answers
2009 Lexus ES350. I would like to know the horn relay location please?
USA SPEC CAR ? (MEANS SOLD THERE FIRST) OR VIN TELLS THIS.
I read the SM, service manual to you, horn schematics.
on 2009 cars, best is check all fuse just in case network errors are cause.
ok no BCM here.
so yes the relay clicks , and closes and honks the horn
shows 2 horns but using ground a23 and a24, got rust there>?
the fuse drives a fuse called HORN
10amp
if you do a 2 mean test, and gay1 honks, and guy2 listens to horn really and you hear it click , that tells you 2 things, horn button good
and CLOCK spring, horn pin not broken
and like magic if it did click, now you found it using EARS.
the book says
engine room R/B and J/B (horn relay)
engine bay fuse box has the relays. not cab.
again USA car left hand drive, not UK or other RHD cars.world wide
1helpful
2015 equinox horn stopped working
If it's blowing fuses, you probably have damaged wiring to the horn, not a bad relay (relays generally fail open rather than with a short to ground). Find the horns (GM usually uses two horns to play a chord), and inspect the wiring to them. Look for a bent terminal shorting to ground, or some spot on the wire where the insulation has been cut or worn by contact with metal. In particular, if the car has been in an accident, check the areas where there was body damage (if the horn relay was bent up by an accident, that may be an exception to the general case that relays themselves don't usually blow fuses.
Where is the fuse controlling the horn on 1998 Buick lesabre
first, an owner should always have a service manual
or an operators manual at a minimum
http://www.vadengmpp.com/owners-manual/buick/1998-Buick-Lesabre.pdf
the horn is fuse #3 on page 6-58
there is also probably a horn relay to consider.
2answers
Repair horn on 2009 honda civic
With the key on but not the engine, press the horn ring a listen for a click, that click is a horn relay. You may need someone to listed under the hood for you, If you don't hear the click, take the covers off the fuse box and see if there is a diagram for the relays that shows a horn relay. While you are checking, look for a fuse for the horn. In rare cases it could be the horn ring or the clock spring.
2answers
Where is the started relay located on my 2007 equinox
The relay should be in the fuse box. fuse box may be located under the hood. or under the passenger side dash down by your feet.
Were is the horn located and i just replaced the horn relay it works but no sound?
Where is the fuse for the horn located in a 2005 Chevy Equinox?
2answers
I need to replace the horn fuse in my 1997 mercury mountaineer
In your owners manual go to the index and look for fuses then go to that page. Look for the horn fuse which should be in the fuse box under your hood around your engine, in your owners manual is should tell you where it's located. Find the fuse for it by looking at the diagram on your owners manual and then pull that fuse out. You should have replacement fuses in the fuse box that's in your car, you have to open the car door to get to it. If you don't have that fuse just take it up to auto zone and tell them you need a replacement for that fuse.
I have a 2005 Equinox, my horn does not work. Where is the fuse box located and/or relay switch?
If u look in your owners manual you should see a diagram of the fuses and their purpose for each! The fuse box is located under the hood on the drivers side,next to the radiator resevoir.there are depression clips that hold down the top of the box on each side, depress them and lift off! You should see the fuses but they only have numbers on them, cross reference them to the diagram in your owners manual. hope it helps
1helpful
2answers
My horn on my nissan sentra is not working. I checked all the small fuses and all are fine. Where else should I look?
its one of two things,check your horn relay or your horn switch is not getting a ground,you can check this by grounding you relay
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
