Question about Brother MFC 210C All-In-One InkJet Printer
Faxing I can not fax. All I get is a dail tone
  • 832 Answers
Did you do the right settings?
Please read manual chap. fax how to set the machine to work for fax abillity for your telephone line. Manual can be downloaded at brother homepage in case you dont have it.
Posted on Nov 12, 2007
How do i get dial tone on fax machine
first, as a tech, i would make sure your phone jack works, then also make sure the line is plugged into the "line" jack on rear of fax. if those two steps are verified beyond a doubt, press your "hook" button and listen for dail tone. if none, pick up handset and listen. if you get tone on handset, then your speaker is disconnected. if you don't get a tone either way, then chances are you have a bad "NCU" board.
good luck,
razors
Oct 19, 2011 | Brother MFC-8220 Fax
I can not get a clear dail tone.
Unplug your fax line and plug in a basic telephone and see if you can get a clear dial tone. If its still bad with just a telephone plugged in then your problem is either within your building or with the outside line...if its ok with a telephone then the line is ok and you may have a dad cable plugging into your fax machine or something wrong with the fax machine itself.
Oct 20, 2010 | Office Equipment & Supplies
No dial tone.
Take the line out of the fax and put it in a telephone,if u hear a dail tone its the fax and if not its the phone line!I am allmost sure there are fuses on the fax board that can be bridged!Good Luck!
Apr 07, 2010 | Canon CFX-L4000 Plain Paper Laser Fax
Fax machine will not send. Dial # Push Send and
If the fax is not set for tone dailing and it is set for pulse dialing the fax will not register the # button.
Dec 03, 2009 | Brother IntelliFax-2820 Laser Fax
I can recv. faxes, but every time i try to fax, I get a dail tone then after dailing the fax number,I am told the number has been disconnected
more than likely, the destination number has been disconnected or changed. this is not an error from your device but from the teleco
Aug 06, 2009 | Dell 2135cn All-In-One Laser Printer
INTELLI FAX MACHINE 775
Have you tried another regular phone on the same jack? There is a small LIU board in the fax that the phone line plugs into and it is possibly bad. Inexpensive board from Brother. Buy a whole unit from EBAY cheaply.
Jun 10, 2009 | Brother IntelliFAX 775 Plain Paper Thermal...
No dail tone
IS THE PHONE LINE PLUGGED IN TO THE RIGHJT JACK YOU WILL NEED TO CHECK THIS OUT FIRST GOOD LUCK BROTHER TECH
Jan 29, 2009 | Brother IntelliFAX 1840C Plain Paper...
Fax problem
Do you have a dial tone?
Dec 23, 2008 | Brother IntelliFax-2820 Laser Fax
Phillips magic5 problem
Hi, I had this problem and spoke to sagem at www.sagem.com/support.
the solution is simple, turn off your fax machine at the wall, take out your batteries from the handset and leave both off for 15 minutes. then turn on the fax machine and replace the batteries back in to your handset, at it will work.....
Jun 15, 2008 | Philips Magic5 Voice DECT Duo - Fax /...
Phone
WHat model is the fax machine? Also check to make sure that the phone line and the fax line are not 2 different phone jacks. Also if the phoneline and fax line are on the same jack, make sure to program the fax number into the fax machine. Also, double check if the fax machine has an in and out phone jack that it is in the in jack.
Feb 21, 2008 | Sharp UX 355L Plain Paper Thermal transfer...
Brother MFC 210C All-In-One InkJet Printer Logo
48 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
