Question about Dryers
Kenmore C11084 7029 0 dryer will not start
The dryer is 13 yrs old. A few months ago, it started to shut off on the auto cycle before drying during a heavy drying load (towels etc). I would set it on a timed dry and it would be fine.
Then,it would shut down on the timed cycle. If I waited a few minutes, it would start up again when the start button was pushed.
Now, it won't start at all. When I hold down the start button, I can hear a faint hum, but that's all it does.
I have cleaned the lint traps, and have a metal duct to the outside.
Any suggestions?
Replace the main motor you have bad motor
Posted on Nov 12, 2007
410e buzzer keeps buzzing after switch is off
sears kenmore dryer when dry cycle is done buzzer keeps ... > Manage My Life > Questions
It can be very annoying when the buzzer to your dryer will not shut off after the ... push to start switch as soon as I close door also buzzer keeps buzzing at end of ...
My dryer end-of-cycle buzzer will only stop buzzing when I ... > Manage My Life > Questions
I see your dryer buzzer will only go off if the door is open. ... Dryer #11079622800: End of cycle buzzer won't stop buzzing after cycle is complete. ... sears kenmore dryerwhen dry cycle is done buzzer keeps buzzing. will not turn off unless you ...
Why won't the buzzer shut off on my Kenmore 80 Series ... > Manage My Life > Questions
The buzzer won't stop buzzing after the load is complete. ... The buzzer won't stopbuzzing unless you open the door or turn on the timer and the dryer will start ...
Keep Your Dryer Quiet - Instructables
Dec 14, 2015 | Dryers
2009 Kenmore Dryer. Wondering why it seems to only work on 1 drying cycle? Everytime I try to put it on another cycle all the lights flash and beep...and nothing...
sounds like the washer might not be spinning the water out of the clothes good enough . 1 60 minute cycle should dry them more than dry enough .
Oct 18, 2015 | Kenmore 8804 5.8 cu. ft. Electric Dryer
Kenmore Elite HE4 Gas Dryer Shuts off prematurely in the Auto Dry cycle and the Timed dry cycle
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
Jul 19, 2014 | Kenmore Dryers
Frigidaire dishwasher model fdb1500fls2
Sounds like the capacitor on the motor is bad,
May 26, 2013 | Dishwashers
Kenmore 80 series Dryer NOT working
I have a kenmore elite , smart pac,he3, it will run for 10 min then shut off and a code (F 70 ) will start flashing, what does that mean.
Feb 02, 2009 | Dryers
Dryer cuts off before clothes are dry.
Might be the thermal protector in the motor that is shutting down the dryer, if motor overheats this is what will happen. Make sure there is no lint build up around the motor, if not the motor is bad. does the dryer start right away after shutting off or do you have to wait? If you have to wait the motor is bad.
Jan 13, 2009 | Kenmore Elite HE4 Electric Dryer
Kenmore Dryer Model 66801692
at leas 15 yrs old??? think it's done its time, its a great machine andwould reccomend replacing with a whirlpool/kenmore unit tworth servicing in my opinion, average call here in new york 150-225, anbd those are for simple issues. id rather put money into new unit! bit be sure to check your venting id say 85% of dryers taking too long to dry are vent related issues
Nov 13, 2008 | Kenmore 62872 Electric Dryer
Dryer shuts off after a few minutes
May 17, 2008 | Dryers
Dryers Logo
160 people viewed this question
Top Dryers Experts
