Question about Canon CLC 1150 Color Copier
Canon clc 1150 copier
does anybody have any information on how to get my canon clc1150 to boot up correctly , the 2 batteries on the cpu board were removed and reseatted , since then the machine starts to boot but the control panel is locked so unable to axcess the service mode or any other function on the machine .any ideas please .
I have an erro paper jam in copier jam the code 0360 what i can do
Posted on Jan 06, 2009
I had the same problem with my CLC 1150. Later it was found the machine was running out of Black Toner. Since the senor on the hopper unit was unplugged, the machine didn't give the 'low senor' signal. Once black toner is filled and INIT-4 was initiated, the problem was solved.
Prem, India
Posted on Aug 22, 2009
This error saysthis:• The toner concentration sensor is faulty/
• The developer inside the developing
assembly is not stirred properly.
• The sensor is subjected to stray light
(no cover, front cover open).
• The photosensitive drum has
Enter service mode *28* and reset error and
Do the stir again and init in service mode to the magenta. must let it go through until it says ready. Check data against intial install data. Did you empty the magenta completely and then put in new toner and then developer? Error 0124 is 01 = magenta and xx24 is:xx24 At time of setting initial
data (as during
installation), the result of
averaging five retry
samplings of PT-SIG-M/
C/Y levels is '683' or less
or that of PT-SIG-K
levels is '305' or less.
Posted on Mar 23, 2008
I have a CLC 1180. The problem is when it prints it stop on the Magenta color and has error E020 with sub 124. I have change both the starter and also change the Toner Density Sensor Unit (FG6-2541-000). Now I can print single colors like yelow,cyan and black but when I try magenta it stops and gives the error. I also change the hopper sensor (FH7-7336-000). Anyone have any ideas?
Thanks Bob
Posted on Jan 29, 2008
  • Canon Expert
  • 287 Answers
Hello flip. I risk being rated poorly by you which will hurt my rating on this site but I'd rather help YOU than worry about it. I bet the status bar that shows the device attempting to load/boot goes just so far and hangs. If I am correct then the system software needs to be re-loaded as the onboard batteries were responsible for maintaining that info. You will have to start the machine in safe mode and reload the system boot firm/soft ware.Hold down the numbers 2 and 8 when you power up the device and you should start in safe mode.This will allow you to load the system software (which sounds like everything but is only the instruction set that allows the copier to access the additional info it need from the sdram and hard drive).However, safe mode merely puts the copier in a state which is receptive to loading the system software. The rest is deep sh%t unless you have the credentials, the data, and the application to install the firmware. I dont mind trying help you further, whatever it takes. But chances are we will need a "dude" on your side (literally) to help us out. Let me know if I can be of help or if you want me to hush. :-)
Posted on Jan 06, 2008
CLC1150 problem code E020 0181
what is this? The machine has been off/on and we also this problem
Jan 31, 2010 | Canon CLC 1150 Color Copier
I own a Canon Laser Color Copier Model No. 1150 CLC1150. The error code when I start up the copier is E0000 0132. How can I fix this issue?
the cause of error is the fixing heater/s is not functioning well .Try this press asterisk with the head then 2 and 8 simultaneously then same asterisk with head. The lcd display will change Pres the ff: COPIER>Function>Clear>Err > ok .to reset fixing error .Switch power off and on the machine.If the Error
return, you have to call the canon service agent to check your fixing/fusing unit and its components
Jun 21, 2009 | Canon CLC 1150 Color Copier
Clc1150 cannot connect to fiery
Your Fiery need"s system software reloaded. let me know if you need help to do so.
May 11, 2009 | Canon CLC 1150 Color Copier
How can i get the CANON CLC1150 to boot up on service mode?
toner cartridge mixute problem
go on line type conan printer error e020 interkey
look threw the problems and see what you wannt to fix the problem best solves the problem
Feb 02, 2009 | Canon CLC 1150 Color Copier
Canon clc 1150
9 times out of ten that means you need a new drum when it does print does it look ok?? if yes then its definatly the drum it measures the voltage on the drum when its worn this code happens sorry
Jan 16, 2009 | Canon CLC 1150 Color Copier
Canon CLC 1150 Boot Problem
your lcd screen is damage replace it
Sep 14, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1150 - E804
it may be the fuse board or the relay near the fuse board that is arcing
May 19, 2008 | Canon CLC 1150 Color Copier
you more than likely need the oil blade replaced. others things can be that you have paper jammed up at the top of the fuser which means youll need to open up the fuser.
May 07, 2008 | Canon CLC 1150 Color Copier
File needed: Printer driver INF for EDOX CLC 1150_Canoncolor
I believe the CLC1150 is a copier only, not a printer.
Mar 26, 2008 | Canon CLC 1150 Color Copier
Canon CLC 1150 Color Copier Logo
480 people viewed this question
old marine
old marine
