ATVs Logo
K
Kathy Light Posted on Feb 03, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I need a battery pack and wall charger - ATVs
Kenneth Blackstock
Level 2:
New Friend:
  • Expert 59 Answers
  • Posted on Feb 03, 2015
Kenneth Blackstock
Expert
Level 2:
New Friend:
Answers
59
Questions
Helped
9381
Points
289
1helpful
How to connect charger to battery on Honda rancher 420tx
https://www.youtube.com/watch?v=b95hA1t7eo8
Jul 23, 2022 • ATVs
2007 Suzuki 250 quad battery is dead doesn't have kick start. Had it on trickle charger for four days still dead. Can I use a jump starter on it if not what are the recommended battery replacement
Hey Michele,, if the original battery lasted this long.. you are lucky,, just replace it. >>> Always use the exact replacement battery<<<<... your quad is designed to take the exact size and amperage rating,, trying to change this is inviting too much trouble,, When you get a new battery,, it will be charged unless you purchase one online that comes with the acid pack,, EITHER WAY - put the battery on the trickle charger for 48 - 72 hours BEFORE you use it.. This will extend the life of the battery a bunch and make it a stronger battery,, ..(this is from too many years of experience.)
1helpful
I had a weak battery but charger on it.I think I must have charged it with to many amps.Now the lights don't work except the reverse light and battery does not hold a charge. Where do I go from here?
Look for a bad fuse or bad connection on the wiring that feeds power to your front lights. Also check for a bad ground.
Until you find fix you can always splice a wire into the hot rear light wire and connect it to your front lights.
Feb 15, 2016 • ATVs
Taotao 125 12 volt atv brand new. Will not stay cranked. HELP 9 year old having fit
You might check the battery charger.... Some of these smaller foreign built ATV's have a battery charger that comes with them. I am not sure what the real problem is tho... Does it crank at all? Does it produce a clicking sound instead of turning the engine over?
Dec 30, 2014 • ATVs
It keeps flashing volts.
Your Charging system is not working. You may need to replace the alternator. The only reason it runs when you are hooked to a charger is your battery is not holding a charge and the alternator is not producing the electricity needed to fire the spark plugs. When you hook up to charger, you now have the voltage necessary to fire the spark plugs.
1helpful
2answers
Wont start or stay running unless battery charger is on it
some four wheelers require a battery to run correctly. sounds like you need a new one.
Mar 26, 2014 • ATVs
I have an electric razor quad,how do I know if the batteries are good or bad,I just purchased a new charger to try that.If that does not work any suggestions.
the charger probably has a meter on it, you can check voltages with it. remember that the battery connectors must be tight, but don't break them.
Can I use the adapter from a 24 volt charger to replace the adapter that connects to the actual battery on a peg perego xp850?
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u.. U can also get free manual works fine .
Jun 23, 2017 • Polaris ATV
'94 Timberwolf 250 2X4 starts great when I have battery charger hooked up, coughs, backfires and dies when I unhook the charger. NEW Battery, fully charged, seems to crank well when charger is OFF, but...
Hey Ccp.. A new battery and it did not help the cranking issue?? hhmm... PLEASE take the battery and have the CCA (Cold Cranking Amps) checked... just because its new and has voltage does not mean its a "good battery"... It takes AMPERAGE to crank and run your machine.. (*see 35 amp fast charge!!)..Autozone, O'reilly's, a battery shop can check the CCA... once you have MADE SURE the battery is good, then you can proceed to diagnosing the real issue...This is the procedure a professional mechanic takes..so do this first... once you have determined the battery is (good or you got a new one)..and ... once you have the machine running,,WITHOUT a charger hooked up.. time to check the output.. you should get 13.5+ volts at 3000+rpm.. if you are not getting 13.5+ volts, its time for electrical diagnosis...This manual should have all the electrical specifications needed to diagnose your issues...
Search Results Page 1 of 1 Clymer Manuals Yamaha Timberwolf 1989 2000 M489...
Jul 29, 2017 • ATVs
Top ATVs Experts
john h
ADMIN Andrew
ADMIN Andrew
Renee Knafel-Bullock
Are you an ATV Expert? Answer questions, earn points and help others
