See Tutorial here
http://www.rcatablets.com/how-completely-reset-your-rca-android-41-tablet
Rate my answer Thanks
SOURCE: How to hard reset Craig 7 inch touchscreen tablet
Most tablets can be hard reset by pressing and holding the power button down for 10-15 seconds. Give that a try.
SOURCE: how do you open a double power 7 inch tablet to remove battery
Have you tried holding in the power button for approx. 15 seconds. This should force the tablel to switch of. Then just switch it on again
contact vendor mfg - shoulds be under warranty
SOURCE: Where would the antenna be on my RCA 7 inch tablet?
It is on the back along one of the edges, likely. There does not seem to be any listing that shows the component locations. If you download a Wi-Fi signal sniffer you may be able to twist the tablet around while pointing it at your ripper to determine which angle gets the best signal.
SOURCE: RCA Voyager 7 inch tablet has no sound. Any
Does it have sound from earphones or external speaker ?
If so bad speaker in cell if
, not send it back for warrented work.
