Question about Samsung CLP-500 Laser Printer
Samsung CLP 500 series Laser Printer
I have the above printer and I keep getting error messages. Replace Transfer belt and replace Imageing unit. I have replaced both and I still am getting the errors. I have tried unplugging, restarting and shutting down but it will not reset. If I just leave the printer on it gets hot and shuts itsef off. Can you help me? Deb
  • 1 more comment
  • shannybells Nov 13, 2007
    Error message states to replace CYAN toner cartridge. Even after it has been refilled.
    Also, can't even close the cartridge door. The yellow toner cartridge does not snap in enough to allow the door to shut.
  • RajW Nov 16, 2007
    Keep getting "Lever Unlocking Error" and "install Transfer Belt" error messages alternating on the display. We've replaced the transfer belt, still get the messages.
    If I need to reset the duty cycle count, how do I get past the error message to the menu and then how would I reset the counter?
  • Anonymous Mar 14, 2014
    Samsung CLX3185 AllInOne Laser Printer reset image unit
  • 217 Answers
If the messages are because the two units have reached their rated page count, you need to reset this via the printer menu system - see user handbook
Posted on Nov 12, 2007
  • PrintDocta Nov 23, 2007
    If you can't close the toner access door, its probably because the top door (access to Transfer belt and Drum) isn't closed fully. This can happen if the locking levers that hold the Transfer belt in position, are NOT fully locked.
    Check that Transfer Belt is properly positioned, lock the levers at each side of Transfer Belt, close top door, toner door should then close.
  • PrintDocta Nov 24, 2007
    The re-filled toner cartridge DID have the reset resistor replaced didn't it ??
    If it didn't, printer doesn't know the toner is full.
    Note - the reset resistor/fuse is NOT just an ordinary 1/4 watt resistor. It is a flameproof fusible resistor. Using an ordinary 1/4 watt resistor can cause heat damage to the casing of the cartridge (at least), and concern at the smoke that can come from ordinary resistors when'blown'
Transfer belt
Try to take out transfer belt and reinstall. You might have to tell the machine that a new transfer belt has been installed.
Sep 09, 2013 | Samsung Image Transfer Belt...
Samsung CLP 500 series printer problem
If you have the manual for the printer look up how to reset it.
also try unplug and push in the power button, then plug it back in and turn it on. let me know if that works.
Nov 12, 2007 | Samsung CLP-500 Laser Printer
Replase your transfert belt
The transfer belt is considered a consumable which means you need to replace it, it has a life expectancey of 50000 black only pages or 12500 coloured pages.
More info
Sep 08, 2009 | Samsung CLP-500 Laser Printer
Samsung CLP 500 Error message 'Replace transfer roller'
You need to enter the hidden engineer menu: turn the printer off then turn on again whilst holding down the enter key on the control panel. It should say something like EDC menu on the display and you can scroll through several menus to find the one about resetting counters. Be careful not to play with other options as you can screw the printer up if you don't know what you're doing!
Mar 31, 2009 | Samsung CLP-500 Laser Printer
"Lever Unlocking Error" Message
Probably a bad connection between the transfer belt contacts and those inside the machine - clean any dirt/toner off them and make sure they aren't bent out of position and try again.
Dec 30, 2008 | Samsung CLP-500 Laser Printer
Transfer Belt vs Transfer Roller
Dear Friends:
I have a same problem after replacing both transfer belt and drum for Samsung CLP-510.
Can you help me?
Aug 20, 2008 | Samsung CLP-550 Laser Printer
Samsung printer, transfer belt error message
Check on you drim uint the gears damaged.
Aug 06, 2008 | Samsung CLP-500 Laser Printer
Samsung printer error
Time to buy a new transfer belt.
Apr 29, 2008 | Samsung CLP-500N Laser Printer
Samsung 600N transfer belt
I fought the "replace transfer belt" message for quite awhile. Then I finally realized I was trying to close the toner cartridge door BEFORE I closed the lid above it. (The printer was close to a wall so I couldn't see the "open and close in this sequence" signs on the cartridge door.) Once I closed them in the proper order, I stopped seeing that message. Janet
Apr 20, 2008 | Samsung CLP-600N Laser Printer
Samsung CLP-500 Laser Printer Logo
402 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
