SCX-4300 SCANER ERROR When I start my SCX-4300, printer is OK, but from...
Dear
Go to TECH mode, doing......(pressing the following keys in serial within 3 secs.)
MENU,copies,<,>,menu,>.
next place a white A4 size paper on platen glass.press MENU scroll to display TESTING press OK, scroll to display SHADING ADJUST press OK . a print out will come.
This will display the status of CIS. if RESULT is OK in the print, Printed at bottom of the page, the printer may work but prepare for the scanner cable (black ribbon type,visible under the platen glass has to be replaced).
Thanks.
SOURCE: samsung printer error ssg_thnk-32 diag error
There might be a firmware update on the printer, try that. Also did you try another network cable? Sometimes they go bad.
SOURCE: samsung scx-4300 error message "toner
You need to change the software of your printer by going to TECH mode and sending some files to the printer.Give me you email so i can send you the instructions and the software if you want to.
SOURCE: scx 4300 printer toner refilled
Hi
replace your chip on cartridge
get a new one
Pls vote me to keep me alive
SOURCE: Toner Exhausted Replace Toner" scx-4300
Hi
You need to raplce chip on cartridge
