Worked on fan switch and resisters until I realized that turn signals and fan and brake lights were all flickering in unison.!!!
It's located on the passenger side A pillar. Or behind the right kick panel ! The first thing to do would be check all Modules for DTC'S ! Yes the BCM need's to be programmed when replaced !
Introduction
The procedures below will program the body control module (BCM) correctly after BCM related service, or setup the sensing and diagnostic module (SDM) serial number in the BCM after the SDM has been replaced. Before you start, read these procedures carefully and completely.
Programming a new Body Control Module (BCM)
If the BCM has been replaced, perform the following steps in order:
After the procedure is completed, the personalization settings of the BCM are set to a default setting. Inform the customer that the personalization must be set again. Refer to Vehicle Personalization in Personalization.
SOURCE: 1998 wrangler turn signal/brake light short
your socket may not be grounded properly, I have seen this before, and the simplest way to fix is change the socket with a new one.Not another used one it may also be bad.
SOURCE: Brake lights dont work, Turn Signals all goofy
First thing i would do is chg. the break light switch, and make sure to chk. all grounds around tailights, sometimes if there is a ground problem it will travel back thru the hot wire to get a ground, witch in turn makes everything go wackey.
SOURCE: How to replace turning signal switch chevrolet
If you have a wheel puller(steering wheel) then the rest is easy. If you don't it's best to grab a repair manual because there are certain little tricks that should be known before attemting to do this.
SOURCE: brake lights do not work at rear of truck ,no
check the relays and connections at the tail lights and under the truck, has the truck ever been off road or in deep water?
Testimonial: "Not helpful"
SOURCE: no brake lights on 2000 gmc 3500, replaced turn
Does it have a trailer hitch and wiring? If so, check to make sure connector is not shorted out and double check your fuses and/or replace fuse. It may look good but I've seen some that were burned out of inspection view. You might also want to trace wiring back to brake lights, just in case snow or build up pull connectors apart.
