Neff H5972N0GB combination oven. Its a new item that was panel damaged at the back. On plugging it in, the panel on the right does not light up to show the settings - normally red back light. With a torch you can see the text but backlight not working. Any ideas if easy fix or need to replace a component or board ? Thanks Rob
SOURCE: ge profile advantium 120, scb1001 oven, display panel out
My GE Profile Advantium120 interior lighting it out .What do i do to replace these bulbs.
SOURCE: thermador oven control panel light is not working
Please see post by bonanzsapilot on 14 March 2009; he gives exact & easy to follow directions for making this repair for <$10. It's listed uner 'Thermador SC301IT oven - FixYa'. In a separate post I added the correct capacitor numbers from Newark.com. I made the fix in abt 30 min & it's good as new. Thermador no longer makes control panels for this oven & no wiring diagram is available to help. Shop price was estimated at $500.
SOURCE: i replaced the control board in a double wall oven
PF simply means a power failure and simply needs to have the breaker reset to accept the new board that you replaced. There are times when you may need to replace the breaker that controls you oven electricity.
Turned off breaker for 30 seconds. Display returned.
SOURCE: I have frigidaire slide-in stove
Most likely it's the clock/timer board that has to be replaced.
Testimonial: "thanks. Can I replace it myself??"
