Kurio Touch 4S Handheld Logo
Jordy Joemar Posted on Feb 01, 2015
My kurio wont finish loading how to fix
Ive tried to reset it and the factory reset but it dosent work at all it just turns on again and starts loading but keeps loading it never finishes
Caine Crosby
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 25, 2015
Caine Crosby
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
523
Points
7
You cant factory reset it. That only works on apple.
I lost the serial number from the back of the kurio. How do i reset profile again?
Restore preloaded content after a factory reset ... - Kurio
www.kurioworld.com/k/us/parents/support/afterfactoryreset
When Kurio prompts you to Create a Kurio User Profile, SKIP this step by ... OnceKurio reinstalls all the preloaded content, you will enter the Owner Profile again. ... the same recovery procedure above, but DO NOT factory reset the device.
2helpful
3answers
My sons kurio 10s has stopped working stuck on smiley face screen how can i fix it
Post an answer to this question...Dear Brandy
Pl long press power switch to make it OFF. then take memory card or sim card from the set. Then power ON if it open go to setting to factory reset and make it rest. Since more applications crunches the RAM and freeze often happen. try to load or move the application to the memory card if any. this will save tabs internal memory.
If problem not solved take to the service center.
thanks
Want to erase password and start over
n order to reset to factory settings, please follow these instructions :
- Power off machine.
- Hold down + first and then POWER for about 10 seconds, release both buttons once Kurio screen loads .
- When you get the open Android picture, press + to enter menu, use - to move down to "wipe data / factory reset" and press POWER again to choose.
- Next press - to choose "YES" and press POWER to start reset.
- Check for yellow text Formatting /data, formatting cache, Data wipe complete.
- Choose reboot system now and press POWER to complete process.
NOTE: This will erase data from your Kurio's internal storage such as Accounts, System settings and Downloaded apps. But music, pictures, and other user data won't be erased. Check "Erase SD card" if you want to clear all the data of the system.
It is also possible to reset only the Kurio Interface: Go to Parental area > Tablet Setup> Press "Reset the Interface to Factory Default Settings".
Once this has been done you will need to set the device up and perform all the updates, instructions for this are on this page.
1helpful
2answers
There are no instructions on how to reset my grandsons kurio7s tablet
check out http://www.kurioworld.com/k/us/parents/support/7/gettingstarted
Kurio7s
In order to reset to factory settings, please follow these instructions :
Please feel free to contact Kurio Technical Support on our support page.
How do i reset a kurio 4S
You can perform a factory reset by holding the volume + button and power button at the same time. Release the power button after 5 seconds but keep holding the volume + button until a screen appears with options. Use the volume + button to scroll down to factory reset and then press the power button to select it. Next you will have to scroll down using the Volume + button again to highlight yes and press the power button to select. Once the reset is finished, you have to set up the tablet again, but at least it works. Hope this helps.
I dont know the password to my kurio 4S
Loading issues
how do i get my per loaded games back on my kurio 4s
Someome put the lock on when you turn it on and can't get in, it has the time and 9 dots how do I get past this
You will need to do a factory reset:
5helpful
2answers
How to reset kurio tablet? Won't turn on at all
my kurio tablet wont turn on, i have tried charging it and turning it on , and answers on google
Top Kurio Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kurio Tablet and eReader Expert? Answer questions, earn points and help others
