SOURCE: I am living in a
As long as the fresh air intake pipe to the furnace is not plugged up the second vent is not needed some homes when they are new are air tight and need a fresh air circulation system
SOURCE: unbalanced cooling or heating
You need to balance the system. It's a matter of adjusting the dampers or registers so that you have a little less air flow near the T-stat and more to the other end of the house. Likely you have a return vent near the T-stat. That return draws air to it and likewise the T-stat. If you are getting a lot of air out of the registers on that end of the house damper them to force more air to the other end of the house. Do not close them entirely though. You may have to play with it a little to get it right. I hope this helps. Please remember to rate Fixya rate me.
SOURCE: Half of the house is blowing cold air the other
Sounds like a broken duct off the main plieum.
SOURCE: fan blowing air not coming in the house blowing threw vents
check to see if those ducts have dampers if the do make shure there open and if they are open maybe close some of the others to balance or improve the preasure in the ducts that arent blowing enuf
