My Epson printer grabs only the right corner of the paper when printing, wrinkles it and stops feeding it through. Help! We can't get anything to print. Very frustrated, this printer is only 1 year old.
Ha it worked! tilted it upside down and out came a dust ball...
Brillient I thought it was stupid but turned it over and a screw came out and then worked perfect
Had the same problem, after reading this thread I hold it upside down and a quarter popped out!!!
I told my wife it was not necesary to put coins in the printer for it to work (joke, I probably threw it in by mistake).
It is a design flaw of the printer, things fall inside because people (including me) leave things on top of the scanner cover, which happened next to the paper feeder.
I had the same problem and what I finally noticed was that something had falled off the shelf above and lodged itself way up in the paper feed slot. It was basically invisible at first and produced the exact symptoms that you described. Unplug, hold upside down and give it a good shake. It's worth a shot.
Same problem, right after I changed all 4 ink cartridges.
grabs right and wrinkles paper and stops
Epson Stylus CX3810 printer/scanner purchased abt. a year ago has same problem....When trying to print, the machine grabs corner of the paper being fed so wrinkles the paper and jams or stops feeding the paper.'
This seems to be a common problem....this problem should be resolved by now.
tried shaking printer, but paper still misfeeds. any other suggestions
same problem, right corner gets grabbed and then expensive ink gets wasted. Tried shaking it but no luck. Any other solutions?
