contact the machine manufacturer's customer support and you can ask them what error E5 is you could also ask for new manual and that might have error codes in it , make sure you have serial number and 12 digit number .
You may get better help if you care to provide some details about your machine, such as the brand name and the exact model number.
Different manufacturers have different meanings for error codes.
For example, E5 on some brand could mean the water heater of the machine is not functioning, but on another brand it could mean that the debris filter is clogged!
Let us know if this has been helpful to you.
Error code 5 means : Required temperature not reached. Causes/Trubleshooting
Thermoblock has blown - replace thermoblock. Power electronics is defective - replace the triacs of the power board or the whole power board. Attention - determine resistance value of the Thermoblock to avoid subsequent errors.
need to replace the camshaft sensor also in tandem w/crankshaft sensor. trouble codes need to be removed from computer. after repair. both the air & fuel filters need replaced. how's your oil change doin ? try this brandi, see if that takes care of it .
E5 mean: The Fine cartridge may not be installed properly,or the Cartridge may not be compatible with this machine.Install the appropriate Fine cartridge.If lines are misaligned or the resulting out put is not satisfactory,carry out the Fine cartridge Alignment.
Ok what you need to do is call your local service company and have a technician come out and check your Thermostat, its currently not able to read humidity probably due to a power surge
HI, you got a mechanical error on your printer this is because it got a paper jam problem and that may result that your printhead slams. Try to look if there's something in your printer that preventing the gear inside to move. If so re install again the driver software of your printer.
