Vacuums Logo
Mary Quickstad Posted on Feb 01, 2015
Rainbow vacuum cleaner won't turn on. - Rainbow Vacuums
FSO34688
Level 1:
Scholar:
  • Contributor 35 Answers
  • Posted on Feb 05, 2015
FSO34688
Contributor
Level 1:
Scholar:
Answers
35
Questions
0
Helped
6742
Points
98
The 4 main problems we see is #1 The Plug needs replaced due to lack of continuity and #2, the 2 pole 2 throw on off switch has failed on the 120 V motor side of the switch.
One side of the switch is for the main motor and the other is for the power to the power head socket on the vacuum it self.
The 3rd is the motor brushes are seized due to a dirty motor or 4, the motor's armature is blown
Check the continuity of the 120 V cord first, then proceed onward.
I hope this helped!
William R
5 Related Answers
Anonymous
  • 1673 Answers
  • Posted on Jan 05, 2008
SOURCE: remove suction motor on rainbow vacuum
Take off the water tank, remove the screw, should be four, that will separate the 2 pieces, remove the rubber seal, remove the screws, 8 If I remember, disconnect the wires to the motor, it should pull out. Replace motor, hook up the wires, screw it back together, glue the water seal back on.
Anonymous
  • Posted on Mar 23, 2008
SOURCE: rainbow d4 model wet/dry/vacuum cleaner
Go here.
http://www.zianet.com/alkone/Manuals/Rb_d4/rb_d4.htm
Anonymous
  • 11 Answers
  • Posted on Jul 03, 2009
SOURCE: can not get the housing off
Remove the 4 screws on the bottom of the canister, and also carefully remove the water basin gasket. You will reattach the gasket with rubber contact cement when you're finished with your repair/cleaning.
Anonymous
  • 84 Answers
  • Posted on Nov 05, 2009
SOURCE: how do you wire in new switch on rainbow vacuum
Hello. I am sorry but, if you don't already have the knowledge to do this, I would strongly reccomend you do not attempt it. Rainbows have a large wiring harness. Here's the main reason: Rainbow vacuums are designed to work with a water filter. If you wire the vacuum wrong, or, if one of the connections come loose, it could mean a possible injury to yourself or damage to the unit, which I know you paid good money for. This repair should only be handled by a qualified vacuum service tech. Thank you.
Anonymous
  • 4 Answers
  • Posted on Dec 31, 2010
SOURCE: WHERE CAN I GET HOLD OF A USER MANUAL FOR RAINBOW
Try this site
http://www.rainbowsystem.com/rainbowsystem/manuals/
2answers
Rainbow E-Series Vacuum cleaner. Where can I find a Rainbow repair man near me zip code 95642.
Question edited for clarity.
Contact Us - Rainbow® Cleaning System
rainbowsystem.com https://rainbowsystem.com > Support
Contact Rexair's Customer Service Department if you have questions about any Rainbow product, including questions about authorized repair and maintenance.
Or
https://www.google.ca/search?q=vacuum+cleaner+repair+near+me
2answers
My rainbow stop working.no red lights.3 times try to start and then switch off by itself.what should I do?
PDF]3 - Rainbow
rainbowsystem.com/.../Rainbow_e2_2011_R14449A-1_English_P...
RexairAs part of Rexair's Customer Care program, each Rainbow and Power Nozzle receives a ... If the Rainbow is not working ... Do not clean the unit or unclog the hose until theRainbow is switched off and the plug is removed from the wall ..... alone or with the Jet Brush attached. ..... The Power Nozzle brush is stopped and.
My Rainbow Vacuum Cleaner Won't Turn On ' eHow
Rainbow keeps shutting off Vacuums Questions & Answers ...www.fixya.com > Forum > Tags > keeps shutting off > VacuumsRainbow vacuums keeps shutting off related questions and answers. ... My Rainbowstopped running I was using the Rainbow and it stopped running. ... the switch . my electrolux has the same problem but wont always turn on.so it probably is ...Three common problems with Power Nozzles and how to fix ...
Where can I get a step-by-step procedure for rewiring?
[PDF]Rainbow Vacuum Schematic - WordPress.com
https://carniomosdirt.files.wordpress.com/.../rainbow-vacuum-schematic....
We carry the Rainbow Vacuum e2 (Black) Main unit parts. to our schematics page and download the schematic that ... Question about Rainbow E series Canister Wet/Dry.Vacuum ... We carry everything from the OEM electrical cord,. Upright .
[PDF]rainbow vacuum manual repair.pdf - WordPress.com
https://arahentau.files.wordpress.com/.../rainbow-vacuum-manual-repair....
Recent Rainbow E series Canister Wet/Dry. Vacuum ... Rainbow Vacuum E SeriesFilter Queen Vacuum Wiring Diagram Oreck rainbow vacuum cleaner.
How to get to the rainbow SE vacuum off/on switch.
Hi, here is a walkthrough on how to get to that part here. Steps 1 - 14 on how to access it, you will need to take apart the housing to get at it. If you need a new switch you can find that here. Rainbow did redesign this switch, so you will need to look at the wiring diagram if you are installing a new switch.
GoodVac.com Technician
www.goodvac.com
1-800-775-6586
Flashing white light rainbow vacuum cleaner
The motor brushes are bad. If you continue to use unit it will damage the armature which is very bad.
Rainbow vacuum won't power on.
Do you have it on the water pan? All models above the eSERIES will not run without the water pan.
RainVac
www.rainvac.com
800-523-0510
Why would the motor of a Rainbow E series vacuum cleaner be made
The bearing for the single speed eSERIES is available on our website. Click here
RainVac
www.rainvac.com
800-523-0510
Top Rainbow Vacuums Experts
Mike Cairns
Mike Cairns
Thomas Perkins
Thomas Perkins
Kardoc
Are you a Rainbow Vacuum Expert? Answer questions, earn points and help others
