Question about Zebra TLP 3842 Thermal Label Printer
Printing Round Labels
Hi, I am trying to print onto round labels 17mm and it keeps going off line after printing one. I fwe manage to print two off it skips a label so either way we are ending up losing halp of our roll of labels.
  • 53 Answers
The issue sounds inpart to be related the set lable length, the printer thinks that the data will not fit on the label and gives the error. also note that the gap sensor is not in the center so the printer will not and can not autodetect the media correctly. you need to tweak the label setup. you could trick the printer by centering the labels over the gap sensor or if you do a autocalibating use the lable size it give you which would be much smaller then 17mm
Posted on Nov 21, 2007
It keeps printing the same label nonstop usless I unplug it
You can select the number of labels to print prior to printing. Go into the print screen and cancel.
Apr 01, 2014 | Dymo LabelWriter Thermal Printer
Keep labels from coming off
It seems like its inevitable, you print your own labels at home and then a few months or even weeks later those labels are starting to peel off. With one small tip you can keep those labels from coming off. What I have been doing with the labels that I put on my kids school supplies is rounding off the corners. After I print the label and trim it down to size I just trim off the corners to make them round and it works wonders. This works simply because when you have a sharp corner it is easy for stuff to get in under the label and then before you know it the whole thing is coming off. By rounding the edges you make it harder for stuff to get under it.
on Sep 15, 2013 | Office Equipment & Supplies
Intermec printer prints slow
The print speed is surely the bottleneck. I did find this:
Page 65 of the manual discusses adjusting the print speed, for "fingerprint" not IPL. (I'm not sure what that refers to, but it appears to be the language used by the printer.)
Jan 20, 2018 | Intermec EasyCoder PM4i Thermal Barcode...
Mis-alignment during printing of labels sheets
Solution!! Use "HP premium Plus Photo Paper" for the paper type setting. Works great with Avery labels & card stock as well. (business cards had the same alignment problem)
Mar 23, 2009 | HP DeskJet F380 All-In-One Printer
Printer labels do not line up with document as typed in Word using the Avery set label size. I type labels for Christmas cards. Previous years have had no trouble at all on other printers but now top of...
The only way I could get round it was to type one page of the labels, then print on plain paper. Check with label size then go back to screen and individually change the labels that were misaligned. Then when I printed on to a label page it was correct. Time consuming but at least I didn't waste any labels that way, only paper.
Nov 21, 2008 | Office Equipment & Supplies
Label Printing
I had the same issue when using Avery labels, here's what resolved it for me.
Go to Control Panel, Printers, go to the active default, right mouse click, click Printing Prefrences..., change the drop down "Type is:" to 'Other Photo Paper" and apply.
You should then be good to go!
Feb 10, 2008 | HP DeskJet F380 All-In-One Printer
Printer keeps printing blanks...
We have found a reset that we use.
We unplug the printer and then we hold down the feed button and we keep holding down the feed button while we plug back in.
It goes through some sort of a reset and this sometimes works.
Jan 23, 2008 | Dymo LabelWriter 400 Turbo Thermal Printer
Printing die cut labels on Zebra Z4Mplus?
Set the printer to transmissivefrom reflective gap sensing.
This will cause the printer to loog for the inter-label gap to tell it where the top of the label is at.
Steve Weinrich
LazerTek, LLC
Dec 15, 2007 | Zebra Z4Mplus Label Printer
First line not printing
It sounds like you are trying to get too much onto the labels or onto a sheet of labels. Try a few pages with a size smaller font and if that solves the problem, the issue is too much info for the epson to fit on.
WP will push the limits of any printer if you make it do so like this and the printer maker may have rounded the specs in the driver.
Update your driver.
Try changing from inches to cm or points etc to see what the limits are.
Then respect that the printer can do no more with that particular driver.
Good luck
Oct 16, 2007 | Epson LQ-590 Matrix Printer
Zebra TLP 3842 Thermal Label Printer Logo
310 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
