The tension of the top thread and bobbin thread are in a "tug of war". If the top is "winning" or too high then the bottom thread will be showing on the top of the fabric. If the top is "loosing" or too loose then the top thread will be pulled through the fabric and show a lot on the bottom. They must be evened out so the "tug of war" is even so the knot is in the middle of the fabric.
START WITH BOBBIN FIRST: Remove bobbin and bob from finger. When you have it adjusted right then the bobbin will extend one inch when you bob it. If you can't bob your bobbin you will have to make an approximate and replace. You may have to do this a couple times to get it right.
WHEN IT'S RIGHT: The bobbin and top tension are equal without being too much pull on both that causes the fabric to pull together.
