Masterbuilt BUTTERBALL Indoor Electric Turkey Fryer Logo
K
Karen G Johnson Posted on Jan 31, 2015
I need a replacement part: No. 10 - Item no.
Break-away cord/Electric cord unit
  • gena mundwiler Feb 01, 2015
    Hi Karen G Johnson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
willie1e
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 29, 2017
willie1e
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
223
Points
I NEED THE INNER POT W/VALVE
Dymo PC 10 electric label maker. Looking for cables?
Are you sure is is a 'PC 10'? I can't find that model. All the ones I have used were battery operated desktop use or hand held. Is this a cable that connect the label maker to a PC, so you design on the computer and print to the Dymo? If that is the case, It _should_ be a standard printer lead.
10FT USB2.0 Printer Sync Cable For DYMO Label Writer ...
Walmart https://www.walmart.ca > 10FT-USB2-0-Printer-Sync-...
100% BRAND NEW, NEVER USED; Cord Length: 10 feet 3M; Compatible with: DYMO Label Writer 450 Twin Turbo label printer; PC and Mac compatible ...
· ‎In stock
USB Cable Cord for DYMO LABELWRITER 310 320 330 ...
eBay https://m.ebay.ca > ... > USB Cables, Hubs & Adapters
USB Cable Cord for DYMO LABELWRITER 310 320 330 400 450 TURBO LABEL PRINTER 6ft ; Quantity. 3 sold. More than 10 available ; Item Number. 364268793499 ; Brand.
NiceTQ Replacement PC/Mac USB Data Sync Transfer ...
Best Buy https://www.bestbuy.ca > ... > USB Cables
NiceTQ Replacement PC/Mac USB Data Sync Transfer Cable Cord For DYMO Label Writer 450 Twin Turbo Label Printer. Model Number: 308139549170. Web Code: 14840651.
· ‎In stock
Dymo PC 10 search results.
https://www.google.com/search?q=dymo+PC+10+electric+label+maker
I plug in cord to charge unit. Light goes on. I put unit down, light goes off. I twist cord, light flickers. I lift unit up and twist cord light goes on. I put unit down or lie it down light goes off. Unit...
You have to use the same diagnostic procedures that you already have to isolate which area of the cord is broken. Carefully test, by wiggling, etc. the end of the cord that plugs into the wall. If this end is faulty, you can purchase a plug end at a hardware store and replace it.
If the cord is broken at the sweeper end, unless you can open and repair the break, you will probably need a new charger.
Gary
Feb 21, 2011 • Vacuums
Need a break away power cord for the 3.5 Quart Deep Fryer model # RHDF260A. Where can this cord be purchased?
Trimmer seems to go to far up and does not trim at
Your trimmer is broken and will need to be replaced if you want it to work properly. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-7680-syncro-lower-unit-p-642.html
To replace, you will first need to gently pry off the 'cap'on the bottom that surrounds the hole for the cord. Once removed the side grips will easily pull away revealing 4 screws on the back. Remove screws to take off the back then lift out the internal components. Reassemble with new case in reverse order
1helpful
2answers
Works sometimes...
Braun Model 8985
It sounds like when the foil is on, there is something causing the blade to 'lock up'. My guess is that the cutter bar between the foils may be damaged and can not move. This would lock everything up. You can check it easily. Take off the foil and turn it over. There is a plastic piece in the middle that transfers the motion of the cutter to the bar betewwn the foils. You sould be able to easily move it back and forth with your finger. If it doesnt move, you will need to replace it. You will find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-360-complete-foil-and-cutter-p-143.html
If this part does not seem to be damaged, the motor brushes may be worn causing the shaver to not have enough power. Was your shaver running slowly or weakly prior to having this problem? If so, the drive unit will need replaced. You will also find this item at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-8000-series-activator-motor-drive-unit-p-36.html
To install, you will first need to gently pry off the 'cap. on the bottom of the shaver that surrounds the hole where the cord plugs into to. You can use a small flat screwdriver or similar object to do this. Once it is removed, the side grips will pull away revealing 4 screws on the back. Remove screws to take off the back cover. The internal parts will then simply lift out. Reassemble in reverse order.
2helpful
Shaver Stopped. May need power unit series 569 class 2 for series 1 150
By 'power unit', it appears that you are referring to the power/charging cord. If this is the item you require, you will find this item for model 150 (series 1) at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/cords-chargers-and-stands/braun-charger-cord-for-select-models.html
2helpful
Remington 14" electric chain saw (model 075762J) does not get sufficient electric power to rotate
I went here and entered your model number.
Remington.com
http://www.desaparts.com/index.htm
  • Type "YourModelNo" into the "Model #:" window, then click search.
  • Click the YourModelNo - Remington Electric Chain Saw "View Model" link.
  • Click “View Owners Manual” or "View Illustrated Parts Breakdown" link.
Clicked on the "IPB" link and found
Item 3 - Armature, pn 100933 $60.34 BackOrdered with no delivery date.
Item 9 - Field, pn 098042-01 $48.76
Item 4 - Bearing, pn 075676 $5.60
Item 10 - Gear, pn 059606 $7.25
Item 11 - Internal Gear, pn 107713-01 NoLongerAvailable.
I would inspect Item 11, I think you will find it failed and is not allowing the motor to rotate. It is also likely the brushes (part of Item 9) have worn away. Least likely is Item 3 is defective. Your unit is either not repairable or will cost in excess of $50 to repair. You can try an Internet search for any needed parts not available at RemingtonPower, we can do no more.
RemingtonPower has stopped all production. Many replacement parts are no longer available. If you can repair it today the next time parts are needed e-Bay may be the only source. I recommend you apply the money toward replacement with a name brand unit you expect to be in business for 10 years or more.
Please do not punish me because you are unhappy with RemingtonPower. I provided a very good answer; although probably not what you wanted to hear. HTH
Lou
Dies in the water. Then wiggling electric cord that connects directly to aquabot sometimes will get it going for a short time, but not always.
It's very common for a cord to have a break internally on this cleaner. Unfortunately the fix requires you to send the unit away for service. Sorry...
Top Masterbuilt Kitchen Appliances - Others Experts
john h
Are you a Masterbuilt Kitchen Appliances - Other Expert? Answer questions, earn points and help others
