Dell Latitude D600 PC Notebook
Problem for Dell Latitude D600 PC Notebook
Dell D660 hinge broken
By Julius80 on Nov 12, 2007
The left LCD hinge of my d600 get broken, I order the new part but I have no idea how to replace those. Are some instructions available? Any suggestion is realy welcome!!
Comments:
Dec 06, 2007
- I found the both LCD/hinge on eBay (around 10$ + shipment), and thanks to Tom19511 I found and download the service manual of d600. In two hours I open the laptop and replace both hinge, now is working perfectly!! Problem fixed!
Clarification Request
Posted by bismin on May 28, 2009
Solution link . . . www.Laptop-Problem-Sollution.com
Same Problem
Jan 02, 2009
-   I have a broken hinge on my dell xps 1710. Where do I get the hinge and how do you replace it.
Mike
-   Guest
Nov 02, 2008
-   Hinge assembly is broken, the support the hinge slides into...-   Guest
Sep 03, 2008
-   The hinges on my D600 both broke, I thought? So I bought used hinges from a computer shop, but much to my surprise when I got it apart, the hinges were fine, but the sleeves they go into were broken! I can not find anywhere, replacement parts and do not know the part number or what to call them. Can anyone help? -   cameraeye
Dec 06, 2007
-   I have the same problem AGAIN. I fixed the right hinge, the left seemed ok. Now both hinges are broken along with what the right hinge attaches to. This time hinges are twice as much as they were a few months ago. No more Dells for me!
Calsgrama-   Calsgrama
Nov 28, 2007
-   I need to replace hinges for Dell Latitude D600 laptop. I have no idea how to do it.
Can anyone help?-   cegu
Best Solution
posted on Nov 12, 2007
Very Helpful)
tom19511
Rank: Guru  Dell Expert
Rating: 85%, 2173 votes
Here you can download the service manual for your laptop.
It will show you what you need to know.
http://support.dell.com/support/edocs/systems/latd600/en/index.htm#online_documentation
Comments:
Dec 06, 2007
- Julius80, I am glad to hear that you fixed it yourself. You probably saved a lot of money. (unfortunate for me, LOL) That is what this site is for. Thanks for the update.
Was this helpful?
Yes
No
2 people thought this was helpful
Solution #2
posted on Feb 03, 2008
Helpful)
nytemayr
Rank: Apprentice
Rating: 88%, 7 votes
Removing and replacing the hinges and latch are easy. However, you do have to pay close attention to which screws go where.
over assembly comes off (the plastic part with the power button) with a very small flat screw driver, it just pops off, be careful to not bend it much.
once that is done, unscrew the hinge areas and carefully lift the LDC screen top out and lay it down.
There are at least 5 screws under the little rubber dots. you will have to carefully pry these out and maybe get some replacement stops or glue them with rubber cement (recommended). Unscrew the 5 screws and set aside from other screws as to not get them mixed up.
then just as carefully as the step one, unsnap the cover from the LDC side of the screen. you will not how the assembly goes together. If your memory is not that good I suggest taking pictures of how and where it goes back together. there are going to be 2 micro screws DO NOT GET THE MIXED UP. once it practacally falls apart, I suggest laying each of the parts right next to the outside edge of the parts you are replacing.
Now just carefully swap each one out remove the latch first and set aside since it will be the last to go, then remove each side one at a time replacing with new hinge as you go.
once you have replaced the left and right side then place the latch back and begin screwing the assembly back together. and check for holes missed at least twice.
carefully position the posts downward and slip the LCD in place. you may want to carfully push back the LCD flat since that makes it easier to get to the screws that anchor the LCD to lower half of the computer. then just snap the hinge ocver carefully.
NOTE, the Bottom portion of the LCD screen cover is very thin, but it wask a small amount of force to snap the cover together. happy repairing.
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #3
posted on Aug 18, 2009
Not Rated)
laptop_part
Rank: Guide
Rating: 0%, 0 votes
You can find the instruction on the link below.
http://scott.yang.id.au/2007/06/repairing-hinge-dell-d600/
Was this helpful?
Yes
No
Solution #4
posted on Dec 05, 2008
Not Rated)
man of man
Rank: Apprentice
Rating: 0%, 0 votes
MATE THE BEST SOLUTION TO THIS IS ON THE SCREEN THERE ARE RUBBER THINGS ON THEIR TAKE THE 6 ROUND ONES OF AND UNDER THEM ARE SCREW USING A SMALL PHILIPS UN SCREW THE SCREWS. ONCE YOU HAVE DONE TAKE THE FRONT PART OF THE SCREEN AND U WILL BE ABLE TO SEE FURTHER. U IWLL BE ABLE TO SEE THE HINGES SO TH HINGE WHICH IS BROKEN ALL YOU HASVE TO DO IS TAKE IT OUT AND REPLACE IT WITH THE EXACT SAME HING.
Was this helpful?
Yes
No
Popular Solutions for Dell Latitude D600 PC Notebook
Questions and Unsolved Problems for Dell Latitude D600 PC Notebook
Do you recommend Dell Latitude D600 PC Notebook?
Answer
Answer
My D600 does not respond when it is plugged in and charging. If I unplug it, it works fine. It... (More)
Answer
my pavilion dv2000 will not boot up past start up screen. can i download a boot disk or recovery... (More)
Answer
my dog chewed through the power cord on my dell D600 lap top and killed it, i bought a new power... (More)
Answer
trying to get on texas holdem stops half way
7 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Nov 25, 2007
Where can get hold of Dell D600 hinges??
Comment by kwhit, posted on Nov 19, 2007
Where can i find the hinges? I have spent the entire morning on the phone with Dell and they were no help.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Dell Latitude D600 PC Notebook:
Top PC Laptop Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more PC Laptop Experts
Top Computer & Laptop Repair
(513) 874-3306
We fix and repair laptop motherboard no video, no...
LaptopOnCall Inc.
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
