Warning: not only would this void the manufacturer's warranty but it could also damage or destroy the product; & you should take or use the necessary precautions to avoid electric shock or any other health risks. Since the AC power cord plugs into the back of the camera, hardwiring a power cord would require unit disassembly & replacing the manufacturer's intended power cord connection with the same power cord or one rated with the same specifications at your own risk to cut off the camera plug-in, to separate the wires, & to anchor these wires to the power jack wires of the same polarity. This could require the use of a multimeter & the use of a plastic plug anchor at the border of the hole leading into the back of the unit. The plastic anchor would serve to further secure the cord to the unit & to reduce unintended entry of moisture, dust, debris, & so forth. Take further precautions if you intend to solder the power cable to the associated wires, & secure the wires at the connections, isolating each new connection with electrical tape, Plasti-Coat, or the equivalent.
