How do I troubleshoot the scooter to make it work. I just replaced the batteries
SOURCE: battery charger wont switch over to charge on a sonic scooter
The Sonic has an off board charger. IF the scooter is not charging, you may need to replace it. If you a technically inclined, you can measure the voltage out of the charger, it should be more than 28 V. You may need to contact Pride for more help.
SOURCE: Pride Sonic Scooter
You can check the voltage going to the motors. The clicking you hear is the brake releasing. most likely, I bet water or something got on the controls and the signal is not getting to the controller. I hope its not the controller, they list for around $350.
SOURCE: Replacing the battery on a mobility scooter
hi, ok remove the seat by turning it to the left, there is a lever normally on the right side that will allow it be turned round,
once you done that, lift the seat in a upwards motion, the cover should come away by gemerally lifting it, it should be attached by velco underneath,
you should now see two batteries. 40Ah batteries will allow you to go further if the battery Ah is lower, 50ah batteries again will allow you can go even further NOT faster, if you buy the larger AH batteries please make sure the dimensions of the batteries will fit within the scooter battery holders.
Regards
GeWiz.
Testimonial: "Thanks so much for the help. The seat did come off in the end but with difficulty. Batteries now changed OK. Thanks again. "
SOURCE: instruction manual for pride mobility sonic & celebraity scooter
Here is the link to all pride manuals for power mobility.All files are .pdf and searchable.
http://www.pridemobility.com/resourcecenter/Downloads/Product_Owners_Manuals/product_owners_manuals.asp
SOURCE: battery won't charge, how do i take battery out of
Remove the seat by depressing a lever on the right side of the chair and pulling upward. there is a boot that covers the shaft of the seat rest. remove the boot and check for a pin with a ring on it. Once this is gone remove the shroud and you will find the batteries. Remove them with care and do a cursory check of all connectors. Some units have a 30 amp fuse on series with the batteries. Make sure the fuses aren't causing your trouble. Be certain to replace the batteries with the right polarity (positive to positive, etc...) Hope this helps.
