Emergency lighting in a residential building fails to come on when power fails. what could cause this?
SOURCE: tail light malfuction
check the brown wire on the tailight harness on the truck chances are it shorted and broke away from the assembly. the fuse is in the junction box under the hood.
SOURCE: Enigine fail safe mode
Sounds to me like the mass airflow meter, cutting in and out. When faulty it can completely shut a car off, and also ingauge limp mode. I hope this helps. Let me know how you get on.
SOURCE: my 97 honda civic dx check engine light keeps coming on
Had this issue did you replace the exhaust
SOURCE: All head lights failed. Display reads: left front
they could fail in pairs, check bulbs ,remove and install new ones also check fuses after installing new bulbs if they dont work because they sometimes pop the fuse when they blow out , also theres a left and right lamp fuse so check both fuses , but only if lamps dont work after you install them. hope this helps, good luck.
